GoogleNestTeam
Community Manager (Admin)
Update 3/20/25
Update 3/17/25:
Update 3/14/25:
Update 3/13/25:
Update 3/11/25:
Hi all,
Thank you.
Thank you for your patience.
GoogleNestTeam
16,162 REPLIES 16,162
chi3
Hello I am using cromcast from last 7 years ,this is first time cromcast stooped working , this is terrible , I can comect cromcast to tv from last 6  daysp, it's shameless from Google,  I thinking to buy prime fire stick
                                          From
                              Chirag shah
                       M 9825678182
PRAB_tech
No need to buy, just set your phome date 7th march and setup as usual
Nadiak786
Hi is there any update to Chromecast fix? Thanks
ZainoChristmas
Please let us know how to fix the problem if you already did a factory reset of the device and when you think the bug fix could be available. Many thanks.
JuniorBarbeiro
Tem data prevista para funcionar?
hemsona153
I did factory reset then found this page. then i changed my phone's date to 06march2025. then paired chromecast again. that way atleast it is connected to internet, though casting wasnt working yet. i waited for few days and yesterday i started my tv just to check if any update is available. suddenly my chromecast started updating, it took 10 minutes but finally problem is solved. thanks google, i was about to switch to diffrent service provider, u saved a customer.
rhizomewu
When will the issue be fixed?
MarleneLodahl
I need instructions to set my device back up as soon as possible.
Fladr72
For those who have factory reset: Change the date of the phone/device you are casting from to March 6th and you will be able to connect to Chrome cast. After connecting you will receive the update and it will work.
PGM00
Thanks, I did performed the factory reset and the issue is when I try to link with the Wifi - up until there it shows on the TV and the app but then when you want to make internet connection does not work. if you couljd support?
ricardoreis
Marked as answered without an answer for all of us who, doing their best to resolve the issue thinking something had change on their end, reset the devices to factory (as recommended by Google on the troubleshooting threads for Chromecasts not being able to connect).
What shall we do to unbrick chromecasts reset to factory? What's the ETA for this to have a solution?
Thanks.
Vittorio67
Any update?
More than one week is already spent and Chromecast still doesn't work!
raab
Thanks, I re-enabled my Gen2 ChromeCast after a few weeks dormant, and it crashed my entire network last week. Needless to say I've unplugged it.
prantzos
Networks don't usually "crash" and don't fail that easily, especially due to communication errors from ChromeCasts, unless they contain malicious content. 🤷
Maybe try again by changing your phone's date to the 7th of March and set ChromeCast up again. Then it should receive the fix via the internet.
Jums2
Bonjour
Mon chromecast ne fonctionne toujours pas lundi 17 mars
LilynM
How long this gonna take? It’s been like this since last week! So annoying!
DrWig
my chromecast audio came back on-line yesterday.....if you didn't factory reset it, it should be soon....
PRAB_tech
2 mins
DaveW3
Mine's working again and I had done a factory reset on it. I changed the date on my phone back to 7th March as suggested.
Fabiospillo
Risolto modificando data su telefono  07032025 poi si aggiorna
Hai semplicemente modificato la data dalle impostazioni del telefono? Io avevo eseguito il ripristino e ora sembra che si debba aspettare per un ulteriore aggiornamento, dato che era sconsigliato il ripristino, che comunque è la prima cosa che uno prova a fare.
Avevo fatto il factory reset, Ora ho modificato la data è fatto aggiornamento usando un telefono Android (con Apple il workaround non funziona). Ora quanto meno è collegato alla rete ma ancora non trasmette, occorre attendere un ulteriore aggiornamento?
Una volta che si collega al Rotterdam e quindi alla rete il chromecast esegue gli aggiornamenti necessari da Internet.  Durante la fase di aggiornamento non perdere il contatto visivo con Google Home perché ti chiede di completare la configurazione. Perlomeno ti sto parlando di quella che è stata la mia esperienza. Ho dovuto fare una nuova configurazione del Chromecast. Come quando il dispositivo è stato appena acquistato.
NandoC
Volevo dire Router e non Rotterdam.  Rotterdam l'ha messo lo smartphone
Airlala
Any news???
気まぐれヌコ1224
初期化してしまいAmazonなどの買い替え検討しています1日でも早くよろしくお願いします
Memyself
When you will be done fixing it,  or I should buy a new one other brand?
It's essential for me & it has been several days now
Hi Memyself, the issue was resolved last week. Folllow the steps in the comments
Johst17
Har varit utan tv nu i 1 vecka..
jpp_
I confirm that one of our devices has been updated and it is workin.
The other (we have two in two meeting rooms) not (I hope not... yet!)
Thanks.
PS: none of them were factory reset.
JLL1
Nada ainda sobre a atualização do Chromecast?????
HansNootdorp
It is amazone and very dissapointing the ChromeCasts are not working anymore at all for more than a week !!! And most likely for 10000's of users....
Verre bad service of Google the fix takes such a long time....
Hi HansNootdorp, the issue was already fixed. Just follow the steps in the comments
anaguipt
Finally solved. Those were the steps:
1 - turn off automatic date and time on ipad
2 - change date to March 1st
3 - reset chromecast
4 - setup on google home
5 - turn on automatic date and time on ipad
Thanks for all your tips
ANDRE666
Hola
Cuando se solucionará esto? Quien se hace cargo del tiempo que estuvo obsoleto el chromecast?  Este corte del servicio que estaba  garantizado se tiene que resarcir.
Espero respuesta
Ya hay una forma de resolverlo si lees entre los comentarios. Tenes que cambiar la fecha de tu celular anterior al 9 de Marzo antes de conectar el chromecast estoy te permite saltear el problema del certificado vencido y programarlo a tu red wifi luego en forma automatica le va a llegar una actualizacion con el nuevo certificado. Talvez no resuelva el tiempo que perdiste pero vas a poder utilizarlo de aca en adelante. Suerte!
Suenilton01
Já faz duas semanas que o Chromecast não pega
tkizzle
Google needs your chromecast device to be connected to wi-fi in order to get the fix. If you did a factory reset on your gen2 chromecast it's offline.  I did a factory reset on one of my 2 chromecast devices.  The one that stayed online received the fix and is working.  In order to get the one I factory reset back on wifi, I changed the date on my cell phone manually to previous 9 March 2025.  That allowed me to connect and set up the factory reset device to my wi-fi.  After a few hours the device received the fix update and is now working.  Hope this helps those who are still offline waiting for instructions from google.
Cat2a
C'est ce que j'ai fait jeudi. Ça a fonctionné jusqu'à ce matin. Ce matin mes chromecast sont déconnectés et impossible de les reactiver
tkizzle
Email received from Google:
Update regarding your Chromecast device
For users who have performed a factory reset, you will need to update your Google Home app to the latest version (3.30.1.6 for Android and 3.30.106 for iOS) to set up your Chromecast (2nd gen) or Chromecast Audio device again. The app roll out is beginning today and may take up to a few days to roll out to everyone. Updates will be posted in the Google Nest Community.
