GoogleNestTeam
Community Manager (Admin)
Update 3/20/25
Update 3/17/25:
Update 3/14/25:
Update 3/13/25:
Update 3/11/25:
Hi all,
Thank you.
Thank you for your patience.
GoogleNestTeam
16,161 REPLIES 16,161
You have to set date on your phone, not router. Just turn off automatic set of date. It worked for me as well, since I rebooted everything and couldn't connect again, BUT still don't recognise divice, which is projector in my case. I think, we just have to wait
It works for Android
Lom
It works
I prefer to wait new instructions directly once Google will have fixed up the issue...
I'm understanding. But think to this: how can the device be fixed if it's not connected to your home wi-fi? So, if you've factory reset (as me, following the procedure!) I suggest to attempt to complete the setup with that trick. After all is a not invasive method 😉
That's what I've thought too...
im not messing around with my iphone. i will just wait to they get a fix. im sure it will be soon, along with reset instructions. 😩
Deu certo aqui, obrigada!
Anonymous
Not applicable
What will happen after factory reset which I already did. How can this happen and is there a timeline for the fix?
If you did a factory reset, adjusting your phone's date & time manually would let you successfully connect to the chrome cast gen 2 again by temporarily turning off the following in order: "Automatic date and time" > "Set time zone based on location" > "Automatic time zone", from your Android device. Set the time to March 3, 2025 then, do a fresh start of Google Home App by closing the app and then open it again and try to add and setup the device. I successfully reconnected my device back into my home wifi network and back to "Untrusted Device" due to firmware issue again when trying to stream or cast videos. Now it is a waiting game for the GoogleNestTeam to fix the firmware/expired certificate issue. All the best GoogleNestTeam and goodluck!
Wili18
A mi me paso lo mislo y no se como arreglarlo
Tinapryce
I have tried a factory reset on my Google Chromecast, it now says it’s connected to my WiFi but it can’t communicate with my iPhone, I have tried turn on my local network, which didn’t work, I have tried resetting my router, I have tried connecting using sidd, I have trying uninstalling and reinstalling the google home app and I have tried using another device to set up which is giving me another error that it can’t authenticate.
Wilma2
Same Problem Here in Holland…..
bjornn
GOOGLE is quiet about global issue 2nd gen chromecast, and no info available at official website
G-ManQ
Its out here in Australia too.
Same issue in Taiwan
All of my calls are getting dropped on Wi-Fi. I have three Google nest in my
How do I get help with my call iPhone calling
Same in spain
lo mismo m pasa desde ayer, estoy en perú, por favor como poder solucionarlo
Denmark too
Same problem here. Accidentally disconnected the cable from Chromecast and unable to reconnect. Tried rebooting everything. It always ends up with “family room tv may be setup, but we could not communicate with it from your iPad or iPhone . Make sure etc…..
MagG
Same in Ireland
JS45
Same for me since yesterday in France
Ik heb dit probleem sinds gisteren (in Hongarije), alles gaat goed tot op de allerlaatste stap: melding: ER IS IETS MISGEGAAN 'xxxx is mogelijk ingesteld, maar we kunnen niet met het apparaat communiceren vanaf je iphone'.  Ik heb alles al 30 keer geprobeerd (router restart, chromecast fabrieksintellingen, et cetera et cetera) maar niets werkt. Chromecast 2 en iphone 7s.
Wilma2
Ja super irritant hè, ik heb mijn ipad net 2 dagen terug in de tijd gezet, maar ben nog niet veel verder dan dat de setup wel kan alleen het casten blijft hangen ....
Pacelli
Kreeg het advies om datum terug te zetten naar 7 maart en dan kan je installeren alleen gaat het dan weer mis met het dtreamen
Pacelli
Streamen
Bro set 7march date in phone then try
Yes! That worked! Thanks!
Yes now it worksbut i couldn t stream
I tried that and it did get further than before but still stops at connecting to wifi and then just freezes
WillIV
Did you try entering the Wi-Fi password manually instead of automatically? I've seen people mention that it should be done that way. I'm not sure what the difference is though.
Si de conecta pero sale error al querer conectarme a las plataformas
Same here in Spain. With setting back the date I could install it again but not able to stream. Get a message of an old firmware. Amazing,no response or solution from Google.
If you did a factory reset, adjusting your phone's date & time manually would let you successfully connect to the chrome cast gen 2 again by temporarily turning off the following in order: "Automatic date and time" > "Set time zone based on location" > "Automatic time zone", from your Android device. Set the time to March 3, 2025 then, do a fresh start of Google Home App by closing the app and then open it again and try to add and setup the device. I guess it is the same idea with iphone. I successfully reconnected my device back into my home wifi network and back to "Untrusted Device" due to firmware issue again when trying to stream or cast videos. Now it is a waiting game for the GoogleNestTeam to fix the firmware/expired certificate issue. All the best GoogleNestTeam and goodluck!
DianaLadaru
Guys, this is taking too long. It's been two days now since Chromecast stopped working. With thousands of unhappy customers all around the world, I think you're taking this too lightly.
Carlo90
both Android and windows 10 show chromecast icon but no connection works. On HDMI TV Cromecast shows as usual photos but no netflix or others connection works. Say no wi fi on chromecast. Until yesterday it worked well.
HKV
Cromecast suddenly don’t link up on our WiFi. It have worked for years with no change to settings and so have all other devices on this WiFi network.
Cromecast is the only device suddenly not working.
Have tried all the power of router, phone ets options. New setup done with same password I’m running out of options; any suggestions?
Faranak
Hi. I have had the same problem since yesterday! No changes or anything else, sudden disruption after 9 years. I have also tried restarting all but doesn’t work.
Perni
I have the same problem.
