GoogleNestTeam
Community Manager (Admin)
Update 3/20/25
Update 3/17/25:
Update 3/14/25:
Update 3/13/25:
Update 3/11/25:
Hi all,
Thank you.
Thank you for your patience.
GoogleNestTeam
16,122 REPLIES 16,122
Giampy51
Purtroppo ho ripristinato il mio chromecast pensando fosse un mio problema. Ora che succede?
gm3con
niente, l'ho fatto anche io. Dobbiamo solo attendere che Google aggiorni l'app. Poi ripartiremo dalla configurazione. Niente di che.
Fumi
I did a factory reset 😡 Why didn't Google announce the issue sooner?
tbuz
Look at other posts asking this question.  Directions on how to set up your Chromecast have been posted.  You're Chromecast won't work, but it will not be factory reset anymore.
Shan24
Any timeline when can we expect the solution?
ccouto
As we can see, after 1750 unanswered posts, Google is not nest but nasty. I have never seen a company treat it's customers like that. Thanks Google to expose your real face. Not need an update anymore
ReyTarzan
Agree!
Pisstake
Sort it out will you... Piss take billionaires
Jaybit
It s outrageous. Without warning or any explanation? First I Scoured the internet,no info there (and yes I do know how to use Google search) I did what any sane person would do and reset the device to factory settings. Since that didn't work I retrieved another Chromecast from my drawer and that was my fix. I am curious how long it will take the brilliant minds at Google to fix this problem that hit millions of users
sam8882004
I have the same problem. Do you know how long it can take to fix the problem? Thank
Bex11
Hi, for those who already factory reset, will you publish new instructions here or somewhere else?
tbuz
If you factory reset your Chromecast, you can fix it this way. Manually change the date on the device you use Google Home to March 8 or earlier, and you can set up your Chromecast.  Then change the date on your device back to what it should be. You won't be able to use your Chromecast, but it won't be factory reset anymore.
Mettester
I'm looking for other streaming options. It's just not okay for this problem to take so long to fix. This makes me loose confidence in Google solutions.
WillIV
The problem itself could take some time. I could see up to a week. However, communication would have been the easy part. I agree that they should have let us know or made some type of announcement and keep us in the loop. It is poor customer service that they've avoided making any kind of public statement.
gizmogremlin
My chrome cast not working .  Can I get a refund ?
Rovert10
Es raro lo que pasa, ya que si cambio la fecha de mi celular lo puedo configurar aunque luego siga sin poder hacer casting...me parece que saben lo que pasó pero no lo quieren solucionar, una estafa.
DSosa
Por favor necesitamos una solución. Gracias!
Julian77
Chromecast authentication error; cannot be authenticated or connected to the wifi network
Since yesterday, the Chromecasts have unexpectedly disappeared from my Wi-Fi network. When I try to configure them again, I continually receive an error message that the device cannot authenticate with my mobile device/tablet. Following the instructions on Google Help, the factory settings have been restored. What will I do? It turns out that it is not advisable to do so. When will there be a solution to this problem?
tbuz
If you factory reset your Chromecast, you can fix it this way. Manually change the date, on the device you use Google Home on, to March 8 or earlier, and you can setup your Chromecast.  Then change the date on your device back to what it should be. You won't be able to use your Chromecast, but it won't be factory reset anymore.
Rovert10
Tengo cuatro Chromecast de 2da generación por confiar en Google, si no lo quieren arreglar por lo menos que me den un reembolso razonable.
rsmaximiliano
I have the gen3 that is not working…
Rovert10
SILENCIO COMPLICE...!!!
Jaybit
We're 64500 views later,did anyone at Google issue a reply yet?
They silently turned off dozens of millions of users, do you believe they care about 65K?
Good because they show who they are, the most disrespectifull company ever seen
MarthaCat07
Hi Google Team:
On March 10th, the day of the outage, I was trying to cast content normally but I couldn't. I was looking for outages and I didn't find any information on the internet.
I hope you can fix the issue, because the hardware (the device) it's still good. I spent the entire day trying to resolve the issue.
Please send a notification or email for people with the Google Home App. Like that we can read and follow your instructions to setup the Chromecast again.
Thank you.
tbuz
CEinCville
I don't see how to set my phone to an earlier date... I wondered if it had to do with the time change on Sunday in the US. The whole thing's just annoying, Class action suit maybe for pain and suffering? 😂 and access lost on all the streaming platforms we subscribe to?
Anonymous
Not applicable
Dopo tre giorni che non funziona, dici di non ripristinare, io penso sia stata la prima cosa che hanno fatto le persone appena non ha iniziato a funzionare.
Olby10
Are you going to force us to buy a newest device? I didn't expect from you---- I guess, you're wrong this time. Thought Google was different
Ralgo89
I I have already reset the data...now what do I do? Do I throw everything away?
tigur11
I just factory reset it too, now Google told not to do it... now what.... 😆
Mushu.
Max98
Set your phone to march 8, you can get it back on the wifi but you can’t stream. We all have to wait till google comes with a update.
CEinCville
Thanks, haha, googled how to do it and did it. It said it was connected of course it doesn't actually work, but perhaps as you suggest it is no longer "factory reset."  You are so clever! Thank you!
no, expose google at all your social media
pulkittt
Frustrating. Waste of time.
Anonymous
Not applicable
I have three Chromcast 3rd GENERATION installed in my house and all of them stopped working on March 09, 2025. Is necessary Google to be aware that the Chromecast failure is not only with 2nd Generation devices.
Kelly10
Nossa falta de educação com os clientes de vcs, pagamos caro no aparelho e por conta de ter lançamentos novos bloqueados os antigos,estou no aguardo para resolver porque não consigo usar a TV para nada sem o Chromecast.
publica o descaso em suas redesnsociais
Kelly10
Vou reclamar onde puder eles que resolvam isso
Willowisp28
Whay do you do if you've ALREADY factory reset?
I literally cannot link my phone to the Chromecast anymore!
