GoogleNestTeam
Community Manager (Admin)
Update 3/20/25
Update 3/17/25:
Update 3/14/25:
Update 3/13/25:
Update 3/11/25:
Hi all,
Thank you.
Thank you for your patience.
GoogleNestTeam
16,147 REPLIES 16,147
Ivy_Doem
Into the third evening of it not working. Is there any update GoogleNestTeam?
miketaylorimage
Thank you nest team for your help. Can you email instructions to fix when ready . I know you guys are doing your best
SineadB1
Is there afix to this problem yet. Still can't connect my chrome cast
Don't know be patient
There no excuse for taking this long, obviously.
sarulee
When can we expect this to be fixed?
I already did a reset before I found out it was a global problem.
MC3659
Please get it back up and running as soon as possible.
SusanDubb
Please keep me posted. Same issue. Did fabric reset my device. Can you please provide me from info asap?
Christian3
Would be very cool if we put the do not factory reset info a place thats a little more visible and accessible than a forum.
jmil
Still not working WTF
Armed5153
How will we be notified when the issue has been resolved?
piltdown
Resetlenmiş cihazı nasıl kurtaracağız?
Denisevadiletti
Teria uma previsão pelo menos de quando voltará ao normal?!??
wood6699
I have already done the factory restart. Do we look on here for instructions?
NZsportbiker
Did the factory reset, as is the default repair response.
Then researched the problem and did the date rollback trick to get the Chromecast back online.  Now waiting for update to fix Chromecast.
Posted here to add to the crowd of affected people.
mhoyosga
Patience is running out
Mgr100
Lo arreglarán también para los de primera generación?
sergioG1
Rimandate un aggiornamento che escluda o resetti quello che è stato fatto
CMG41
Last night I unplugged my 3 year old (Ithink) TV  chromecast as I needed to use the plug to charge a phone. Later I put the plug back in and tried to stream Netflix as normal. No luck. Ive uninstalled, reinstalled, reset, rebooted. No luck. Any suggestions ? Thanks.
Mgr100
Si, esperar a que Google tenga a bien revertir la actualización que ha hecho…
El problema no viene porque lo hayas desenchufado
Sayluna
I did a factory reset yesterday before you guys made any official statement - I was just following the general advice on your website. Hope this doesn't mean that my chromecast is now just a lost cause
Maqvero
J'espère ce sera résolu au plus vite, en plus j'ai réinitialisé  la chrome cast. Dommage on n'aurait dû avoir un message d'erreur clair. Merci de nous envoyer la procédure pour réinstaller.
LauraDinamita
Please, do you have an estimated date for the fix? It’s now over 24 hours waiting for it. Thanks
TheHylander
Need a fix plz
Davesiant1
Stage 1 fix if you have factory reset. Set your date manually to March 6th. This enables you to set up your chromecast onto your home WiFi.
This doesn't fix the original issue with actually casting but at least it undoes the factory reset while Google fixes the main issue
Are you sure that will work as a temporary fix? Would it help if my Chromecast device could not access my Wi-Fi because the login passwords or the network were blocking it and the setup process was not getting past this? Was that because I reset the Chromecast to factory default settings? Thanks if this can be confirmed.
Jhaafke
Me too! Is this actually current for March 11, 2025? How will you notify so I know where to find the fix?
TotiBaradero
Hice lo que me pidió el ADM de este chat. Cambie la fecha del teléfono  al día 9/3 Y volví a intentarlo desde Home pero no sucedió nada bueno. Ahora me dice que el sistema no esta adaptado al Pais en que vivo, Es una vergüenza que esto suceda con los costos de los equipos.
AdrianBv
Casting is working in my case after using the workaround described on :
https://www.androidauthority.com/how-to-fix-chromecast-authentication-errors-workarounds-3533849/
Activity manager app can be installed from Samsung Galaxy Store :
https://apps.samsung.com/appquery/appDetail.as?appId=com.activitymanager
JC258
Worked for me too. Happy it was on Samsung app store. Don't like downloading apks
SCottyDo
Please, Any idea of when this will be fixed? When is the next release cycle planned?
gabrieloui
Are you doing this because you want us to throw away our chromecast and buy something new?
Don't you think that when we bought it we chose you and trusted you?
If it doesn't work anymore, not only will I never buy a device produced by you again and I will change completely but I will spread the word to everyone not to buy your products because they have an expiration date even if they are not broken.
This is real madness!
I can't watch any streaming service for which I pay a subscription since 4 days.
This is the right time for me to buy an Amazon Firestick and I say goodbye to you for real!
I'm so upset even beacuse I wasted hours and hours, entire days trying to figure out what was wrong, whether it was the chromecast, the router, or something else, doing resets of everything.
Cla0313
In half the world millions of Google Chromecast devices have stopped working. Yet it was an excellent device and worked precisely and flawlessly until March 9, 2025. So: Google staff, if you don't want to be hated, hurry up and fix the bug and publicize it.
DannisvB
If you have done the factory reset on your chromecast, you will not get it back online. However, if you are an Android-user, you can fool the system by altering the system date of your android device to the 8th of March. Follow the steps below.
1. Open the Home app
2. Now alter the system date of your android device
3. Add your chromecast as a new device in the Home app.
4. Walk through the installationprocedure, and your Chromecast will come back online.
You still can't cast anything, but now you are ready to receive the fix-update from Google. We just have to hope that Google solves the problem with security certificate soon.
Bobalab
And iOS users?
LetyM76
Muchas gracias. Seguí los pasos y lo pude hacer. Resta esperar a que esté solucionado el inconveniente.
Gracias de nuevo.
LetyM76
Y si ya lo restablecí de fábrica? Aguardo su ayuda por favor. Gracias
Bobalab
Too late I did reset, and now?! I have to trash my chromecast?
DannisvB
Read my walkthrough a few posts earlier. But it works only for Android-users.
