Update 3/20/25
Update 3/17/25:
Update 3/14/25:
Update 3/13/25:
Update 3/11/25:
Hi all,
Thank you.
Thank you for your patience.
03-20-2025 10:49 AM
03-11-2025 05:26 PM
Col vostro messaggio Ho notato che è stato rilasciato un aggiornamento di Google Home ho creduto per un attimo che avesse risolto la situazione ma purtroppo pur identificando il dispositivo Chromecast ancora non riesce a connettersi 😭
03-11-2025 05:29 PM
Há alguma previsão de quando haverá essa correção?
03-11-2025 05:36 PM
Bring back Chromecast Audio!!!
03-11-2025 05:39 PM
Thank you.I missed my device very much.Please work diligently to fix the problem.
03-11-2025 05:44 PM
Have already tried to factory reset device. Will you send through troubleshoot details please?
Thanks
03-11-2025 05:44 PM
How will we get the answer?
03-12-2025 04:50 AM
Hopefully on this forum page, bookmark it 🙂
03-11-2025 05:46 PM
2 days (and counting) seems like a really long time to diagnose and fix and expired certificate issue!??
03-13-2025 12:17 PM
Been off for like a week, I thought it was my actual unit, swapped to another one (I have 4) and that was was fine. So idk what’s up
03-11-2025 05:48 PM
Qual a previsão pra resolver isso?
03-11-2025 05:48 PM
Any timeline on the repair
03-11-2025 05:50 PM
You had me digging out this old usb-c to mini Jack adapter I think I got with my pixel 1.
03-12-2025 02:40 AM
Just jacking it noice
03-11-2025 05:57 PM
As you should be aware, your own trouble shooting procedure says to factory reset. You need to accept responsibility for your poor quality trouble shooting procedures and fix this issue.
03-11-2025 05:59 PM
Agradezco que se preocupen y ocupen como corresponde, pero Mi Paciencia y la de casi todo el Mundo se va a terminar pronto, en especial la mía y eso que soy una persona muyyy paciente, den una pronta fecha de solución o acepten que no la hay, nosotros veremos y nos organizamos para ver qué fin va a tener todo esto, saludos
03-11-2025 05:59 PM
When should we expect a fix?
03-11-2025 06:13 PM
First I got "Untrusted device" with no solution. I did a factory reset and not can't connect at all.
03-11-2025 06:20 PM
Por favor mantengan al tanto de las novedades. He reseteado a fábrica el Chromecast y actualmente no tengo forma de configurarlo por no poder conectarme al dispositivo.
03-11-2025 06:21 PM
Still not fixed?
03-11-2025 06:23 PM
They should have told us this 2 days before because it's already a bit late.(Please do not factory reset your device)
03-11-2025 06:26 PM
I appreciate your concern and attention as it deserves, but my patience and that of almost everyone is running out, but mine worries me and I am a very patient person, give a quick solution or accept that there is none, we will organize and see what end we give to all this, this is translated with your translator and I hope you understand it, the next message will be in Chinese, Japanese, Arameo and so on until you understand it, greetings
03-11-2025 06:28 PM
我感谢你的关心和关注,这是应得的,但我的耐心和几乎所有人的耐心都快用完了,但我的耐心让我很担心,我是一个非常有耐心的人,给出一个快速的解决方案或接受没有解决方案,我们会组织起来,看看我们能给这一切带来什么结果,这是用你的翻译翻译的,我希望你能理解,下一条消息将以中文、日语、阿拉姆语等形式出现,直到你理解为止,问候
03-11-2025 06:29 PM
¿Existe alguna novedad o tiempo estimado de solución? Si ya indicaron que encontraron el problema, luego de 2 dias sin poder utilizar el dispositivo, el cual en mi caso poseo 2 Chromecast de Segunda Generación que estan inoperativo, deben indicar al menos un tiempo estimado de solución al ya conocer el problema y su complejidad.
PD: En la app Google Home almacenan los dispositivos vinculados en cada cuenta Google, donde se detalla la información de los dispositivos. Podrían implementar un sistema de notificaciones en la misma App que nos indique este tipo de problema o que nos redirija a esta web, ya que no es correcto que los usuarios se enteren de esta incidencia a traves de otros usuarios y no directamente de Google.
03-11-2025 06:29 PM
J'apprécie votre sollicitude et votre attention comme elle le mérite, mais ma patience et celle de presque tout le monde s'épuise, mais la mienne m'inquiète et je suis une personne très patiente, donnez une solution rapide ou acceptez qu'il n'y en ait pas, nous nous organiserons et verrons quelle fin nous donnons à tout cela, ceci est traduit avec votre traducteur et j'espère que vous le comprenez, le prochain message sera en chinois, japonais, araméen et ainsi de suite jusqu'à ce que vous le compreniez, salutations
03-11-2025 06:30 PM
WTF! Chromecast Troubleshoot: Do a factory reset | Google Nest Team DO NOT FACTORY RESET 😱 now what?
03-13-2025 10:58 AM
Agreed. I followed the instructions that told me to do a factory reset. WTF!!
03-11-2025 06:31 PM
Apprezzo la tua preoccupazione e attenzione come merita, ma la mia pazienza e quella di quasi tutti si sta esaurendo, ma la mia mi preoccupa e sono una persona molto paziente, dare una soluzione rapida o accettare che non ce ne sia nessuna, ci organizzeremo e vedremo che fine dare a tutto questo, questo è tradotto con il tuo traduttore e spero che tu lo capisca, il prossimo messaggio sarà in cinese, giapponese, aramaico e così via finché non lo capirai, saluti
03-11-2025 06:32 PM
あなたの心配と配慮には感謝していますが、私やほとんどの人の忍耐は尽きつつあります。しかし、私自身は心配で、とても忍耐強い人間です。早急な解決策を提示するか、解決策がないことを認めるか、私たちは組織化して、このすべてにどのような結末を与えるかを見ていきます。これはあなたの翻訳者によって翻訳されており、あなたが理解してくれることを願っています。次のメッセージは、あなたが理解するまで中国語、日本語、アラム語などでお伝えします。ご挨拶
03-11-2025 06:36 PM
Agradeço sua preocupação e atenção como merece, mas minha paciência e a de quase todos está se esgotando, mas a minha me preocupa e sou uma pessoa muito paciente, dê uma solução rápida ou aceite que não haja nenhuma, nos organizaremos e veremos que fim daremos a tudo isso, isso está traduzido com seu tradutor e espero que você entenda, a próxima mensagem será em chinês, japonês, aramaico e assim por diante até que você entenda, saudações
03-11-2025 06:40 PM
Tôi đánh giá cao sự quan tâm và chú ý của bạn như nó đáng có, nhưng sự kiên nhẫn của tôi và của hầu hết mọi người đang cạn kiệt, nhưng sự kiên nhẫn của tôi làm tôi lo lắng và tôi là một người rất kiên nhẫn, hãy đưa ra giải pháp nhanh chóng hoặc chấp nhận rằng không có giải pháp nào, chúng ta sẽ sắp xếp và xem chúng ta sẽ làm gì với tất cả những điều này, bài viết này được dịch bởi biên dịch viên của bạn và tôi hy vọng bạn hiểu nó, tin nhắn tiếp theo sẽ bằng tiếng Trung, tiếng Nhật, tiếng Aram, v.v. cho đến khi bạn hiểu nó, lời chào
03-11-2025 06:58 PM
Amomba'e pende jepy'apy ha atención omereceháicha, pero che paciencia ha haimete opavave mba'éva opa ohóvo, pero che paciencia chepy'apy ha che ha'e peteî persona ipasiénsiaitereíva, ome'ê peteî solución pya'e térã acepta ndaiporiha, romohenda ha rohecháta mba'e fin rome'êta opa ko'ã mba'épe, kóva oñembohasa nde traductor ndive ha aipota pentende, marandu oúva chino, japonés, arameo ha upéicha peikuaa peve, maitei
03-11-2025 06:59 PM
Google already showed their customers how inoperative they can get when support is needed. So, why will you people keep waiting for an official solution.
A developer already came up with a fix (reddit).
I don't know if I can share the link here, but you can always google it. I just followed instructions and got it working.
03-11-2025 07:10 PM
Yes, the Reddit fix you're referring to (actually a clever workaround) will restore Gen2 casting for Android devices & Chrome browser. Worked for me. It's not perfect, but it will suffice until Google issues a proper security certificate fix.
Here's the link:
https://www.reddit.com/r/Chromecast/comments/1j7lhrs/comment/mgy1a88/
03-11-2025 11:21 PM
Unfortunately, this did not work for me
03-11-2025 09:33 PM
All credits to tchebb from reddit
Although it's on Google to fix this issue properly, I've found a few workarounds that might get you up and running again, depending on the device you're trying to cast from. Note that I'm editing this comment frequently to refine the instructions and add new ones.
This should fix casting from apps and partially fix the Google Home app. (It now shows me the Chromecast's status, but things like changing the name still don't work.)
Run the following:
adb shell am start-activity -a com.google.android.gms.cast.settings.CastSettingsCollapsingDebugAction
On Android 11 and below, use CastSettingsDebugAction instead of CastSettingsCollapsingDebugAction.
In the settings panel that pops up, scroll down to "Connection" and enable "Bypass Device Auth".
As above, this should fix casting but not necessarily the Google Home app.
Note that, while running with that switch, Chrome will show a notification stating "You are using an unsupported command-line flag". Seeing that is a good sign, but it doesn't necessarily mean you've specified the path properly. If casting still doesn't work, double-check the path and file name.
This adds the expired certificate as a root of trust, which bypasses expiration date checks.
03-11-2025 10:57 PM
i cant find "Intent launcher" in appen kun "IntentResolver", need help!
03-12-2025 11:13 AM - edited 03-12-2025 11:16 AM
You'll Finde "Intent luncher" inside "activity manager app", an app inside f-droid
03-11-2025 07:07 PM
Agradeço a sua preocupação e atenção como merece, mas a minha paciência e a de quase todos está a esgotar-se, mas a minha preocupa-me e sou uma pessoa muito paciente, dê uma solução rápida ou aceite que não haja nenhuma, vamos organizar-nos e ver que fim daremos a tudo isto, isto está traduzido com o seu tradutor e espero que compreenda, a próxima mensagem será em chinês, japonês, aramaico e assim por diante até que compreenda, cumprimentos
03-11-2025 07:10 PM
Much better explanation of this issue on reddit here: https://www.reddit.com/r/Chromecast/s/Z4qr4tyaiF
03-11-2025 07:13 PM
Agradezo a túa preocupación e atención como se merece, pero a miña paciencia ea de case todos estose esgotando, pero a miña preocúpame e son unha persoa moi paciente, dea una solución rápida ou acepta que non a hai, organizarémonos y veremos que final lle damos a todo isto, isto está traducido co voso tradutor y espero que o entendades, a seguinte mensaxe sea en chinés e xaponés, saúdo ata que o entendades aramáico, xaponés.
