08-07-2024 01:09 AM
Hi!
I am trying to find a way to get the remote on my chromecast (HD) to work with my Tele systems Palco 27 TV.
The TV has HDMI-CEC.
That brand is not in the list for TVs in chromecast.
Anyone knows a compatible TV I could use, or any other way to use the chromecast remote for the volume?
Regards
Leif
08-07-2024 05:17 AM
Hello there🙂
Let see if I can help...
You have a TeleSystems Palco TV, which supports HDMI CEC, so lets try the following...
When you first set up your Chromecast with Google TV, it should prompt you to set up the remote for volume, power, and input control.
Now at times it doesn't detect certain brands off TV"s automatically, Lets try selecting a similar brand or opting for "manual setup" to enter the commands yourself.
Pro Tip:📺
Also by plugging the Chromecast directly into the receiver instead of the TV (or vice versa) can resolve communication issues. If your receiver supports HDMI CEC, ensure it is also enabled there.
If all else fails try 3rd party Solutions...
If the built-in features don't work, consider using 3rd party devices, which can integrate various devices and control them within Google Assistant or with the Chromecast remote
Please let me know if any off the above worked.
Best off luck🎲
Leonard Claassens
08-07-2024 05:17 AM
Hello there🙂
Pro Tip:📺
Best off luck🎲
Leonard Claassens
08-07-2024 06:32 AM
Thanks!
I got the volume working without selecting any TV. Changed the setting from automatic to chromecast.
I can live with not having on/off and input select working.
Thanks a lot!
Leif
08-07-2024 07:07 AM
Glad i could assist😉
Blessed may the rest off your day be🔈🔊
08-15-2024 12:18 AM
Found out recently that all apps don’t handle the volyme the same way. In some of my apps in chromecast I can adjust the volume with the settings I found working. In others, like Max, that does not work.
Is that something in the app?
08-08-2024 03:13 PM
Buenas. Tengo problemas con el remoto, se desconecta del dispositivo. A alguien le pasó?? Cómo puedo solucionar. Gracias
08-11-2024 10:05 AM
Hi Emanuel190511,
Thanks for posting. I'm sorry to hear that you are having this situation with the Chromecast remote constantly disconnecting. I understand how frustrating this situation can be. But don't worry, I can help.
Please, try with these steps:
You can check the "Troubleshoot the Chromecast Voice Remote" article for detailed information.
Please let me know how it works after this steps or if you have more questions. I'll be happy to help.
Jenny
08-11-2024 11:48 AM
Hi there!
I see you're in Brazil, and I'm all the way over here in South Africa, but let's see if I can help you out with your Google Nest remote issue.
If your remote keeps disconnecting from your TV, there are a few things you might want to try. First, check the batteries in your remote—they could be running low, and fresh ones might just do the trick. Sometimes, a quick reset can help too. Unplug your TV and Google Nest device for about a minute, then plug them back in and let everything reboot. It’s a simple step, but it often works wonders.
Re-pairing the remote is another option. You can do this by holding down the pairing button on the remote until the LED light starts blinking. Your TV should guide you through the rest of the steps.
Don’t forget to check for any available firmware updates for both your TV and the Google Nest device. Updates can fix bugs that might be causing connection issues.
Interference from other electronic devices or obstacles between the remote and TV could also be a culprit, so try clearing the space around them.
If all else fails, a factory reset on the remote might be necessary. While it’s a bit more drastic, it can often solve stubborn issues. And if you’re still having trouble, you can use the Google Home app on your smartphone as a temporary remote, or contact Google Support for more help.
I hope one of these tips helps you out! Please let me know if my advice has made a difference. Have a great day, and God bless!
08-11-2024 11:50 AM
i translated the above for you🙂
¡Hola! Veo que estás en Brasil y yo aquí en Sudáfrica, pero veamos si puedo ayudarte con el problema de tu control remoto Google Nest.
Si tu control remoto sigue desconectándose de tu TV, hay algunas cosas que podrías intentar. Primero, revisa las baterías de tu control remoto; podrían estar bajas, y unas nuevas podrían solucionar el problema. A veces, un reinicio rápido también ayuda. Desconecta tu TV y el dispositivo Google Nest de la corriente durante un minuto, luego vuelve a conectarlos y deja que todo se reinicie. Es un paso simple, pero a menudo funciona de maravilla.
Otra opción es volver a emparejar el control remoto. Puedes hacerlo manteniendo presionado el botón de emparejamiento en el control remoto hasta que la luz LED comience a parpadear. Tu TV debería guiarte con el resto de los pasos.
No olvides revisar si hay actualizaciones de firmware disponibles tanto para tu TV como para el dispositivo Google Nest. Las actualizaciones pueden corregir errores que podrían estar causando problemas de conexión.
La interferencia de otros dispositivos electrónicos u obstáculos entre el control remoto y la TV también podría ser la causa, así que intenta despejar el espacio alrededor de ellos.
Si nada de esto funciona, podría ser necesario restablecer el control remoto a la configuración de fábrica. Aunque es un poco más drástico, a menudo resuelve problemas persistentes. Y si sigues teniendo problemas, puedes usar la aplicación Google Home en tu smartphone como un control remoto temporal, o contactar con el soporte de Google para obtener más ayuda.
¡Espero que alguno de estos consejos te ayude! Por favor, déjame saber si mi consejo hizo la diferencia. ¡Que tengas un gran día y que Dios te bendiga!
08-15-2024 08:48 AM
Hi LeifAnd,
Thanks for posting. I'm sorry to hear about the situation that you are experiencing with the inconsistent volume levels between different apps on your Chromecast. I understand that the situation may cause frustration. But don't worry, let's work on finding a solution.
To get started, please tell me what Chromecast device you have?
In this case, try adjusting the volume levels individually within each app. Some apps may have their own volume settings. If the situation persists, check your TV's audio settings and ensure "Auto Volume Leveling" or similar features are disabled.
Please let me know how it goes. I'll be waiting for your response.
Jenny
