Volume increasing and decreasing on Chromcast
ditsworth1
Hi!
The volume on my tv keeps randomly increasing and decreasing. I know it is not a problem with the physical remote, because it does the same thing when I use my phone as a remote. I know it is a problem with the chromcast and not my TV, because when I disconnect chromcast this problem does not happen.
virnab
Hi ditsworth1,
Thanks for reaching out to our community.
I’m sorry to hear that the volume on your TV keeps randomly increasing and decreasing. Thank you for sharing with us that you were able to detect that it isn’t a problem with the remote because the same happens when you use your phone. Another important point you mentioned is that when you disconnect your Chromecast from your TV, the problem doesn’t happen. No worries; help is here.
Before I start further troubleshooting, let me ask you a few questions:
  • Are you using the latest version of the Google Home app available?
  • Could you please confirm what the model of your Chromecast device is?
  • Have you tried using your Chromecast on a different TV? Does it show the same behavior?
  • Is your Chromecast linked to a 2.4 or 5 GHz WiFi network?
  • When was the last time it was working?
  • Have there been any recent changes to your environment, such as a change in Wi-Fi network, recent outages, adding more Wi-Fi devices, etc.?
  • What is the status of the LED light that you can see on the Chromecast?
In the meantime, I recommend manually downloading the latest firmware update. Please follow these steps:
  1. Open the Google Home app.
  2. Go to devices. (the square with bars icon in the bottom of the screen)
  3. Select your Chromecast.
  4. Go to 'Settings" (the gear icon).
  5. Choose "System."
  6. Select "About."
  7. Choose "System update."
Virna
