chromecast HD Problem - Green side (left and right) while casting screen from two different laptop.
chessman128
POST UPDATED STILL NOT FIX !
previous post
Please check my other post
Devices
  • TVs: Sony TV (Bravia), Hisense Smart TV
  • Laptops: Infinity Gaming Laptop, Dell Laptop
Issues:
  1. After the February/March firmware update, a green border still appears along the sides of the Sony TV,you always get green bars either on the sides or top and bottom..
    ( see attached link)
  2. (NEW) Both the Sony and Hisense smart TVs no longer display in Stretch in full-screen after the FEB update—regardless of the chosen  changed resolution,
We need urgent support on these issues, as they’ve been outstanding for far too long and are still pending resolution.
Sony tv error
7 REPLIES 7
DeboraJ
Hi @chessman128
Thank you for reaching out to the community! I'm sorry to hear that you are continuing to experience issues with your Chromecast HD. Thank you for sharing the original post and providing the necessary information. Let me assist you with this.
  • I'm just a little curious, are you trying to cast from a laptop to a TV? If so, would it be possible for you to try casting from a phone using the Google Home app instead?
  • Also, could you tell me what you are trying to cast? Are these platforms like YouTube, Netflix, etc., or other websites?
Once you provide this information, I will be more than ready to assist you.
Debora
1. Yes i am casting from laptop, laptop info and others please check the orginal post which is in the first link on this tap post.
I am using Iphone , i don’t know how to cast from iphone mirror screen/ cast from the screen from google home app.
2. even others then Netflix or youtube etc..
please check following link.
Cast screen error continues.
DeboraJ
Hi @chessman128
Thank you for letting me know! I really appreciate the information you provided. Based on this, it seems like there might be some settings related to matching content frame rate. Not to worry! I have a helpful resource for you: a Help Center article about Display settings for Chromecast with Google TV and Google TV Streamer. You will find detailed instructions within this article.
Please check those settings, and afterwards, try sharing some apps on your TV. Let me know how it goes!
Debora
Hi Debora,
thanks for answering , but it still the same.
the frame rate is already selected as match content.
I don't get it, is there a more specific answer?
I need a solution to this please.
DeboraJ
Hi @chessman128
Thanks for letting me know how those steps went. To help narrow things down, let's try this next:
  • In the Chrome menu, go to Settings, then Show advanced settings, and uncheck the box for Use hardware acceleration when available.
  • Close and reopen Chrome.
  • After you try this, if the problem continues, could you please try connecting your Chromecast to a different TV and see if screen sharing works there?
Let me know what happens! I'll be waiting for your answer.
Debora
Hi @DeboraJ
Thank you so much for the reply and your patience. I had too many things to sort out before.
1. The box for Use hardware acceleration when available were already unchecked , in my chrome web browser it's in (chrome://settings/system), dont see any "Show advanced settings" ( Chrome is updated version)
2. Closed and reopen Chrome web browser already, still the same with green banner
( not the mention also done factory reset in Chromecast HD already)
3. done, and is the same.
I needed a next solution to this please.
chessman128
Hi @DeboraJ
I needed a next solution to this.
best regards
