Anyone having trouble with google nest cam battery streaming in live view?
JohnF
Original poster: Martin Horrocks
Notification recording works but not the live streaming view.
Abdallah
I have the same problem with both my new doorbell (battery) and new nest cam.
Everything working fine except seeing live from phone or Google display. Wifi speed is great. Reset didn't work
MH
Did you manage to find a fix?  Mine still doesn't accept live feed....
Abdallah
Yes,
I found the settings in the Google wifi to make it work:
Go to Google home app,
Wifi
Settings
Preferred activities
Uncheck both activities.
mdr2
Hmmmm,  I'm not sure what to chime in with.  My new doorbell(battery) worked fine.  But the fact that both are not showing you video is an indicator that the problem is not on the camera side.
Maybe just double check you are on the newest version of the GOOGLE HOME app?   I think the only way to do this is to go to the app store and search for GOOGLE HOME and see if it says "Update" where the download button is.
