Doorbell chime to not ring on device, but device should still receive reminders, broadcasts,...
JohnF
Original poster: Gary Pugliese
You can setup and use the Nest Doorbell with your Nest Speakers and Displays: https://www.youtube.com/watch?v=j75X1BE6oN4
If you do not want the doorbell chime for the Nest Doorbell to ring on a certain Google Home/Nest Speaker or Display in your Home, you are to enable Do Not Disturb for that device as per: https://support.google.com/googlenest/answer/7552172
The Do not disturb states: Mute reminders, broadcast messages, and other spoken notifications.
However, I would like my device to continue to receive reminders, broadcast messages, and other spoken notifications.  I just do not want the device to receive the doorbell chime.
Will there be an enhancement available to only turn off the doorbell chime on a Nest Speaker or Display?
JohnF
HI Gary,
Please send feedback via your Google Assistant about this feature request. Just say "Okay, Google, share feedback" and then record your message.  It is a great suggestion to have the option to mute certain things like the Hello but allow other notifications. I would use this feature.
The only way to stop the notifications does stop all the notification as you posted. Filters don't get that granular either.
The doorbell has a Quiet Time feature but that will stop the entire doorbell notifications on all your devices.
-from Jill (Product Expert)
