Fitting a nest doorbell chime to a UK wired system where there is no existing doorbell
watsonmj3
Hi I have been asked to help a neighbour install a door bell gen 1 which is brand new but was bought some time ago.  I cannot find any instructions any where particularly about the doorbell chime. How do I fit this in the UK where there is no existing door bell to connect to?
6 REPLIES 6
David_K
If there's  no existing doorbell, you could use a third party indoor power adapter, such as the one below, as I don't believe the Google one is available in the UK unfortunately.
OhmKat Video Doorbell Power Supply - Compatible with Nest
Setup steps here:
Install Nest doorbell with an indoor power adapter - Google Nest Help
EmersonB
Hello watsonmj3,
Thanks for reaching out here in the Community. How's it going with your Nest Doorbell? Were you able to read the information and check the link that davidking has shared? In case you have an update, you know where to find us.
I appreciate the help, davidking.
Hi
I have managed to get a suitable PSU from amazon.  I have used it to power up the bell on the bench.
Not sure if I need to do anything with th chime connector though?
EmersonB
Hi watsonmj3,
Thanks for getting back to us. You may hit this link and watch the video to know the steps needed to install your chime connector. Let us know how it goes.
I appreciate your help, @David_K and Emerson.
Hey watsonmj3,
