08-22-2022 03:00 PM
TL;DR: Google Nest Battery camera stopped displaying a live video feed ("The camera is offline") after a few months via the Google Home app on multiple devices.
I purchased two (2) Google Nest Battery cameras in April of 2022 (about 4 months ago). There were no problems initially. I was able to setup and connect them to the Google Home app. Both are plugged in to power (not using the battery). I was able to see the live streaming feed and historical recording.
About a few months ago, the app started to consistently say "The camera is offline" when I try to view the live video feed for either camera. I have home-away setup for recording alerts, and when I am not home, I still get alerts from both cameras when they detect motion. This happens with two (2) Pixel 6 Pros and one Samsung Tab S8 Ultra (Android 12 and 13).
Google Home app seems to be up to date on all devices (2.56.23.3 on Pixels, Android 13) (2.56.1.11 on Samsung, Android 12). I have also tried uninstalling and reinstalling the app. The router is not far away from the cameras (no more than 30-40 feet away) and neither the cameras or router changed since installation. I tried unplugging and replugging the modem, router, and cameras - still no luck.
I have three (3) Nest Cam IQ (Indoor) that work via the Nest and Google Home apps without issue. I also have a wired indoor Nest Cam (current generation) that also works without issue - its just the two (2) indoor/outdoor Google Nest Cam Battery units that do not want to live stream with the Google Home app.
Besides completely resetting the cameras, are there any other troubleshooting steps I can take? Can I get some insight on why this is even happening to $180 cameras?
Thanks for any help and/or feedback!
08-29-2022 09:22 AM
I am terribly sorry to hear that you're having this issue with your Nest camera! I'm sure it's frustrating but I'm happy to look into this and see how we can help out. The first troubleshooting step that I'd recommend would be to Restart your device. By doing this, it should keep all your settings, and reconnect it to the same Wi-Fi network. This is helpful if it ever freezes, has connection problems, or isn't working normally.
09-01-2022 09:38 AM
Hi Brad!
I would assume restarting the cameras would be unplugging and plugging them back in? If so, that was the first thing I did. Unfortunately that did not solve the issue.
09-01-2022 09:42 AM
You can also try to Factory Reset the device, but you would lose the footage. It is an excellent troubleshooting steps to take if you are willing. I wanted to remind you of some Important things to know before you factory reset. After you factory reset your camera or doorbell:
Important: Because a factory reset permanently erases the items listed above, we don’t recommend doing it as a troubleshooting step until you’ve tried restarting your camera and other troubleshooting options.
09-05-2022 07:21 PM
I appreciate the help, Brad.
Archie
09-06-2022 08:01 PM
Archie
09-01-2022 09:28 AM
Best regard,
