Longer charging cable for Nest doorbell battery
LT2
Is there a longer charging cable for the nest doorbell battery so the doorbell doesn't need to be removed from outside? Not looking for a permanent long adapter,  as I see you can buy these online, but only a longer charging cable.  Thanks!
David_K
There isn't a longer charge cable unfortunately. The only one available is 1m as its only intended to be used indoors. The charge cable isn't weatherproof so isn't supposed to be used outside. If you don't want to remove the doorbell to charge it, the outdoor weatherproof cable is what you'll want to be looking at.
Nest Cam weatherproof cable – Google Store(5m or 10m).
janthadeus
Hi LT2,
Checking in — I just wanted to make sure if you’ve seen davidking’s response. Let me know if you need anything else.
I appreciate your help, davidking.
janthadeus
It's me again. I want to check if you still need help. Don't hesitate to reach back if you do.
janthadeus
Just checking in to make sure that you saw my response. I'll be locking this thread if I won't hear back from you again in 24 hours. Should that happen, feel free to create a new one if you have more questions or have other concerns in the future.
