Nest Doorbel battety doesnot work on samsung family hub
RezaKz
Is there any way to integrate Google doorbell battery with Samsung Falily hub fridge? It looks like not all functions work properly after Nest & Samrt thins integration.
Any solutions?
David_K
As far as I'm aware no, there's no integration that would make Nest cameras work with the Samsung setup on your fridge. Integrating Samsung SmartThings with Google Home, allows you to control some Samsung products with the Google Assistant, as is supported by the product itself as well.
Thanks for reaching out. I just want to check if you managed to see the response above. Please let us know if you still have questions or concerns, as we'll be willing to assist you further.
I appreciate your help, @David_K.
EmersonB
@RezaKz, we wanted to follow up and see if you are still in need of any help. Please let us know if you are still having any concerns or questions from here, as we would be happy to take a closer look and assist you further.
Thanks for answering, Jenelyn and davidking.
EmersonB
Hello RezaKz,
Just one final check in here since activity has slowed down. We'll be locking the thread in the next 24 hours, but if you still need help, we would be happy to keep it open. If there's more we can do, just let us know.
