Nest camera offline with a green light.
MaxDunn
Installed unit, it worked for about a month and then went offline a couple weeks ago, just on it's own. No network outage, nothing. Just *poof* offline. Powered cycled the unit and it came back on for about an hour then went offline again. Has been offline since.
Troubleshooting so far -- (Have done all this today so far)
Power-cycled the unit and router. -- Rest of house sees WIFI no issue. Nest green light went off, came back on.
Replaced the transformer. -- Was an older 10v, checked new transformer for voltage.
Factory reset the unit, removed from app, -- Green light went out, waited a few seconds, came back on. Now I cannot add the nest back in as the app can never connect to it.
Unit is not cold, is not hot, has a steady green light at the top and nothing else.
TireDoctor1
I have the same problem it suck when you pay $200.00 for a camera and this happens
MaxDunn
Fixed by google replacing it. A 1 month old defective unit replaced with a $40 refurb -- champ warranty there. Oh well.
Hey Folks.
