12-27-2022 11:34 AM
Hello - i have a nest IQ outdoor camera which is hard wired correctly - but after 6 months seems to not indicate it is receiving power, and hence not work - tried it with another camera and same - no power 9AFTER SHORT PERIOD OF TIME) . Power lead is still working correctly when attached to other devices to check power output exists - any ideas? Thanks very much.
12-28-2022 08:11 AM
I have a similar issue. I had two cameras installed by ADT yesterday and are both wired. When I view one in the app it shows it is plugged in but the other shows battery that is dwindling because I live in Minnesota. I can't find a way in the app to change from battery to plugged in for the one camera.
01-03-2023 11:41 AM
Sorry to hear you're experiencing this, as I can imagine it has been an inconvenience. I would love to look into this further for you. It sounds like it could be related to wiring, etc. but especially if it is not receiving any power. Have you tried to contact support regarding this? If no, please fill out this form, and a higher tier of support will reach out to you with next steps.
01-06-2023 01:40 PM
Just checking in to see if you have had the chance to fill out the form I sent previously. Please let us know if you have any further questions or concerns. We'll leave this thread open for a little longer for follow-up questions and concerns.
01-06-2023 02:11 PM
Hi Brad,
I haven't yet as I have had a chance to look at the camera outside. We got 15 inches of snow the other day so it's a bit difficult to get anywhere near my camera. I'm planning to do it this weekend though and if I can't find the problem then I'll fill out that form.
Kirk
01-09-2023 08:34 AM
Thank you for the update. We will still want you to fill out the form I sent, as it would need to be completed in order for you to receive assistance.
01-13-2023 07:50 AM
I wanted to follow up and see if you were able to fill out the form? Let me know if you have additional questions.
I appreciate the help, Brad.
01-14-2023 01:34 PM
Hello folks,
