03-31-2023 04:16 PM
My Nest Doorbell latch (the tiny button on the back) is stuck, so when I try to put it back on the mount, it just falls off every time. Is there a fix for this or do I need to get a replacement?
04-02-2023 07:08 AM
You could try contacting Support starting with this link to see whether you need a replacement. There are quite a few posts in this forum regarding problems with the mounting mechanism for the battery doorbell.
04-05-2023 05:03 PM
Checking in — were you able to speak to our support team as shared by MplsCustomer? Let me know if you need more help.
04-08-2023 05:17 PM
Hey BenjaminSummers,
It's me again. I want to check if you still need help. Don't hesitate to reach back if you do.
04-09-2023 05:35 PM
Just checking in to make sure that you saw my response. I'll be locking this thread if I won't hear back from you again in 24 hours. Should that happen, feel free to create a new one if you have more questions or have other concerns in the future.
