doorbell will not keep history no longer than 3 hrs
Golden1
my service is with ADT - everything on there end is working - the doorbell will not hold history more than 3 hrs.
7 REPLIES 7
Golden1
hello - is anyone on here????
@Golden1
I'm just another Google Nest customer (as are most respondents in this forum).
If you are only getting history for the most recent 3 hours, then you probably do not have a Nest Aware or Nest Aware Plus subscription. I don't know how that works with the Google/ADT partnership, but these are the specifics on what you get:
https://support.google.com/googlenest/answer/9681538
And this is the pricing if you purchase from Google:
https://store.google.com/product/nest_aware?hl=en-US&modal=upgrade-pricing
 I have it through ADT - they r the one that told me to call Google
@Golden1
If you are using the ADT/Google partnership (I don't even know how that works, except for what I see on their TV ads), I don't know whether you purchase a Nest Aware subscription through ADT or through Google.
I a quick search, I found this ADT page on Nest Aware:
https://www.adt.com/products/google-nest-aware
If you are purchasing a Nest Aware subscription through Google, you would go here:
If you are getting your Google Nest camera service through ADT, I would think ADT should tell you how you are supposed to proceed.
Golden1
does customer service ever answer on here or is there someone to call???
@Golden1
Sometimes Google Nest Community Specialists post responses here.
But if you want to contact Support:
Golden1
THANK U
