03-29-2022 02:54 PM
Hi ,
I purchased and successfully installed a nest camera (battery) 4 weeks ago
I purchased nest aware plus 4 days ago, but am not able to see any recordings from previous days.
I can only view recordings from today !!
How can I see previous days recordings ?
Thanks 😊
04-04-2022 02:38 PM
I apologize for my late response and thank you for all of your patience while waiting for a reply. I definitely understand how frustrating your situation must be, and I wanted to make sure that your concern was acknowledged. You cannot see previous footage if you did not have a Nest Aware subscription. The events and footage start when you start your Nest Aware subscription. The footage before is lost.
05-12-2022 12:48 PM - edited 05-18-2022 02:13 PM
Hello @hughblue,
Just wanted to check in here to see if you were able to see Brad's response here? Did you have time to dive into the issue you are having? Please keep us posted if you need anything else.
James
05-18-2022 02:15 PM
We just wanted to check in one more time in case anyone else has any follow up questions or comments. If not, we'll go ahead and close this thread in another 24 hrs.
Thank you,
James
05-19-2022 02:46 PM
Hey Folks.
