10-12-2022 07:02 AM
I believe I have a defective unit.
It has been 4 weeks since the chirping stopped. At that time, I put in new Rayovac UltraPro Alkaline Batteries, even though I had new batteries in the unit form the original install. Now the unit is saying, “the batteries in this unit needs to be replaced immediately”.
Being in business, I understand sometimes defective units make it into the market place. I believe Google should replace this unit.
Please advise.
Thank you,
10-12-2022 09:42 AM
Hi @PhilipR
Support will likely tell you to use the required Energizer Ultimate Lithium AA (L91) batteries. If you are still experiencing the trouble with the Protect you should contact support directly for the best way forward with your smoke detector: Contact Us - Google Nest Help
Jill
10-12-2022 10:58 AM
I stated that incorrectly. I had replaced the with Duracell.
10-15-2022 11:33 AM
@JillG, thanks for the help!
@PhilipR, Like what JillG mentioned, Both battery and wired Protect require Energizer Ultimate Lithium AA (L91) batteries. Let us know if you're still experiencing the issue once you installed the recommended batteries to your Nest Protect. You can also click on this link to learn more about this.
Edward
10-18-2022 11:39 AM
Hi PhilipR,
Edward
10-19-2022 10:55 AM
Hi PhilipR
Edward
