Fire Drill using Nest
AmandaL2244
I want to manually turn on the Google Nest Fire Alarm and then off again to do a fire drill with my children but I can't locate how to do this on the iOS app? Is this possible?
davidking
Gold Product Expert
Gold Product Expert
The closet thing to that is a featured called Safety Checkup. Depending on where you start the test, either Nest Protect or the Nest app will give you a countdown so that you have time to move away before the test alarm begins. You can also cancel the test with the app or by pressing Protect's button.
1. Sign into your account in the Nest app.
2. Select Nest Protect on the home screen.
3. Tap Checkup at the bottom of the screen.
Volunteer since 2011, Product Experts are not Google employees.
Mlabrador
Thanks for posting and apologies for the late reply.
@davidking, appreciate the help!
@mandaL2244, davidking is right! Try to run the Safety Checkup first and let me know how it goes.
Nikki
MelbaDT
Hey mandaL2244,
Checking back in — have you had the chance to try the suggestion above?
Melba
MelbaDT
Melba
