Fire Drill using Nest
Fraser42
I want to manually activate the Google Nest Fire Alarm to do a fire drill with my children but I can't find a way? Is this possible?
David_K
David_K
You can do that using the safety checkup feature:
Learn about Safety Checkup - Google Nest Help
Fraser42
Thanks, not quite I'm after - I'm wanting to simulate a fire alarm, like what happens in a commercial building
Safety checkup is the closest thing to that as it sounds the horn. There is no other feature or setting to manually trigger the horn to sound, short of perhaps simulating it with things like smoke alarm test spray products.
