Issue with scalding hot battery in nest protect
on_dre
Had chirping low battery warning, took batteries out and scalded myself due to a battery being SO HOT,
I see others have had the same issue but have had their thread closed.
I HAVE NEVER known batteries to do this and I've had energizer ultimate's in my ADT PIR sensors for years.
Ambient temp of battery, more than 10 mins after removing was 50c. Thank fk I removed them within 5 minutes of the first chirping sound, this was a FIRE hazard.
I've tested all the batteries, none need changing and have good voltage output apart from the one that almost caught fire.......
I am concerned that the heat may have caused internal damage to the unit.
*Stupid label demands, it's neither web or connectivity, it's a consumer safety issue.
12 REPLIES 12
Lance_L
Hi on_dre,
Oh no! We’re sorry to hear that. Let’s check this out — I need additional information from you that would be best shared privately. I’m sharing a link to a form for you to fill out so we can look into this further. This form is only meant for you to use, so let me know once you’re done.
Lance
wtbril
I had exactly the same issue today. Chirping low battery warning of one of my Nests. Which was strange, as I recently replaced all batteries with Energizer Ultimate Lithium. I replaced them again, but don't trust the Nest Protect anymore. I'm wondering what the issue is and whether I can safely continue to use my Nest Protects as I have my have used these through basically my whole home  (8 pieces...).
Lance_L
@on_dre, we got your form — thanks for filling it out. Our team will reach out to you via email to further assist you.
@wtbril, thanks for chiming in. I’m sorry to hear that you’re having issues with Nest Protect. Let’s check it out.
A few questions: do you have a wired or battery-powered Nest Protect? What is the software version of the device? To check, go to the Nest app > Device Settings > Technical Info > Software.
Battery life varies greatly depending on usage: how many times Nest Protect detects smoke or carbon monoxide (CO) and sounds the alarm, how often Path light turns on, where the Nest Protect is placed in the home, etc.
Here are some things you can try to extend the battery life:
Lance
wtbril
Thanks Lance. Here are the answers:
  • Battery powered
  • Model: Topaz-2.7
  • Software: 3.5rc3
The symptoms:
I exchanged, triggered by the Nest Protect, a few months ago all 6 batteries by Energizer Ultimate Lithium batteries.
Monday 11 Dec it started chirping and the app told me to immediately replace the batteries. Which I found odd as I just exchanged them some months ago. Anyway, I did and then burned my thumb on one of the batteries which was cooking hot.
on_dre
This has got NOTHING to do with how often the device detects smoke or carbon monoxide. Mine has never detected either. AND all of the batteries (apart from the one that almost exploded and damaged the Nest device with the dangerous heat output) are full. We are NOT alone or one-off's. Many other people have experienced the same issue and I've seen "closed" threads on here with people having the EXACT same issue.
Lance_L
Hey everyone,
@on_dre, I appreciate you getting back to us. It looks like the previous discussions you mentioned were automatically locked by the system due to inactivity for over 30 days; posts are not being blocked. I have forwarded your case to our support team, and they’ll contact you via email as soon as they have more information to share.
@wtbril, thanks for the follow-up information and for checking that out for us. I require some more information from you that would be best shared in private. I will provide you with a link to a form that you can use to fill out this information. This form is only for your use, so please let me know once you have completed it.
Lance
Lance_L
Hello everyone,
@wtbril, we have received your form. Thank you for completing it. Our team will contact you via email to further assist you.
Lance
on_dre
I HAVE STILL NOT had anyone bother to contact me about this dangerous situation, what's going on LANCE?????
Lance_L
@on_dre, I’m sorry for the delayed response here. Our support team has reached out to you via email. You may continue the conversation on that channel.
@wtbril, apologies for the lack of updates. I have sent a follow-up to the team working on your case. Hang tight; they’ll reach out to you via email as soon as they have more information to share. Thanks for your patience.
@c240amg, thanks for joining the discussion. Do you still need help with your Nest Protect? If yes, I’m sharing a link to a form for you to fill out so we can look into this further. This form is only meant for you to use, so let me know once you’re done.
All the best,
Lance
Lance_L
Hey everyone,
@c240amg, we haven’t seen your form submission come through — were you able to access it alright? Let us know if you’re running into trouble or still need our help.
Lance
c240amg
Had exact same issue.
Removed batteries and they were almost too hot to touch. Binned them in a plastic bag. They were also lithium energizer.
Replaced with a new set. Agree that is'a fire hazard, but not Googles fault, but battery went bad somehow...
iconzo
@on_dre @c240amg @wtbril
I’ve had this issue as well, twice. Google eventually replaced my units but it took quite a lot of checking in with them to get it done. I suggest that, in addition to continuing to follow up with Google for a replacement, you should take a moment to report this issue to the Consumer Product Safety Commission at: https://www.saferproducts.gov/IncidentReporting
I did this after someone suggested in another thread and google appeared to be more responsive after my complaint was published and sent to them by the CPSC.
