09-30-2025 06:13 AM
I have purchased two new Nest Protects as my previous ones had expired. The new ones will not connect to my WiFi. I constantly get a PO23 error if I try to scan them and if I try to put in via the entry key then I just get a permanent spinning circle and nothing happens. What can I do?
10-03-2025 03:58 PM - edited 10-03-2025 03:58 PM
Hi @ChrisG56,
Thank you for reaching out to the Google Nest Community. I'm sorry to hear you're having trouble connecting your Nest Protects to WiFi and seeing the P023 error code. It sounds like the app gets stuck when you try to set them up. I'm here to help.
Please follow the steps below to try to resolve the problem:
If you have any questions or need more help, just let me know.
Gabriela
Hi @ChrisG56,
Gabriela
