1 zone boiler, red and white wires and common
Scueter
Attached is the wiring I have now with a 1 zone boiler, red and white wires.  I've added a common wire for the thermostat from the boiler to keep power on the Nest E.  I'm assuming the white wire goes to the white terminal and red wire to red terminal.  The Common would then go to the C.  Is this the correct wiring for this situation?  I assume the red and white wires are just a dry contact to turn the boiler on /off.
GarrettDS
Hey there Scueter,
I'm so sorry for the delay in our response, but I wanted to hop in here to make sure we addressed your concern. I can definitely understand the confusion when it comes to thermostat issues as it can be very odd to figure out sometimes, but I'm happy to look into this for you.
First off, I would suggest using the Compatibility Checker to see if your system is compatible. Then, if it is, I would suggest contacting a pro to come out to help you with this since I know that the Nest thermostat is not compatible with stranded wires, every wire has to be connected to the Nest Thermostat system.
Please let me know if you have any further questions or concerns as I'm happy to help.
Garrett DS
GarrettDS
Have a great day.
Garrett DS
GarrettDS
Have a great day,
Garrett DS
