Connection issue
Dmusc
Not connecting to my phone app. Both on same wifi. New modem both work but I cannot control from my phone
Phyre
I too am having this issue. My phone says "nest is not connected" I check the nest and it has connectivity to the router and I can see that the wifi is working. The app is just not seeing the device as on line. So I can't change temp. Start the fan ect.
Phyre
Okay so much more digging around if you haven't solved this. You'll have to remove the nest from your nest app and re-add it. The nest walks you through how to do that. Good luck!
Hey Dmusc,
Sorry for the late reply. I wanted to follow up and ensure you are good to go. Please let me know if you are still having any trouble with the device connecting to the app.
GarrettDS
Have a great day.
Garrett DS
GarrettDS
Have a great day,
Garrett DS
