05-11-2022 05:03 AM
My Nest thermostat only has a heat setting. I have air conditioning that I would like to turn on. How do I get the Nest to give me a cooling setting?
05-11-2022 07:25 PM
Did you recently install the Nest or was it working correctly and now isn't?
If you recently installed it, post a picture of the original thermostat's wiring here
05-11-2022 08:13 PM
here is current wiring
05-11-2022 10:30 PM
Was there another thermostat installed before you installed the Nest? If yes, then that's the picture I need. If you don't have the picture, can you post a picture of the terminal block on the control board in the furnace/air handler?
I need to see what the wires went to before the Nest was installed.
Are there also only those four wires?
05-12-2022 04:16 PM
Yes there was another thermostat before and no I do not have a picture of that configuration. I will post pics of the control block in the furnace handler. And yes there are just 4 wires.
I had a professional come out today and he wanted me to ask if a C wire is required for heat and cool operations? He reports there must be something wrong with the Nest because the wiring is correct, the Neat is just not picking up the cooling. He had to install a different thermostat today because it would not recognize my air conditioning. What is my next step? I really want to use my Nest products.
05-14-2022 01:22 AM - edited 05-14-2022 01:24 AM
You have all of the correctly colored wires and they still used the blue wire for Y1, instead of the Yellow wire.
There are a couple of extra white and red wires, any idea where they go?
One pair of red and white wires should be in a cable that goes to the outside unit.
Is there a humidifier or such installed?
I personally always connect a C wire to the thermostat, especially when installing the Google Nest Thermostat. Normally I would say use the blue wire, but since they are using it I would say connect the brown wire to the B/C terminal on the control board and the C terminal on the nest.
I would strongly suggest that you do a reset to factory defaults and set the thermostat up again.
When you are asked in the app to select the wires that you have, I suggest you check these.
W/W1, R, G/G1, Y/Y1, and C (only if you connect the C wire)
05-17-2022 09:11 AM
Hi Kcola,
Thanks for reaching out here in the community.
I'd like to jump in here and check if you've seen Patrick_Caezza's response. Let us know if you need more help by replying to this thread.
Ryan
06-01-2022 04:32 PM
I have the EXACT issue verbatim and none of this is working. I think I’m taking it back for a refund which is unfortunate because I live alone and travel for work and I liked the option of being able to remotely adjust on hot and cool days.
06-01-2022 04:38 PM
Same here.
05-12-2022 05:28 PM
07-20-2022 02:17 PM
Thanks for staying here in the Google Nest Community.
I'd like to check in here if you've tried to perform a complete factory data reset on your Nest Thermostat. The step is helpful after doing some checking and transferring of wire on the terminal.
Ryan
07-24-2022 03:04 AM
Ryan
07-24-2022 05:39 AM
I did try a factor reset & combed the Internet for all available information. Apparently this problem is not an isolated case so I returned the Nest Thermostat. I put the Honeywell unit that preceded it back, rewired as it was and it works perfectly. I think there is obviously a documented issue with this design and I wouldn’t recommend this equipment to anyone.
It’s unfortunate because I did like its aesthetics and my ability to make changes, tie in with future ‘Home’ products in one app and monitor while traveling for work; none of that makes a difference if it can’t provide basic functionality. Thanks for responding.
07-24-2022 11:11 PM
Hi Morgs52,
Thank you for being here in the Google Nest Community.
We are always learning and continue to work to make our product and services even better. We really appreciate your feedback through the community.
Ryan
07-28-2022 04:02 AM
Ryan
07-29-2022 05:36 AM
Melba
05-11-2022 08:08 PM
I had my furnace replaced 12/2021. I bought the Nest thermostat then and installed it at that time. It worked fine for the heat. This is the first time I have tried to use it with the a/c.
I have a photo of the wiring, but am unsure how to attach it to this message? Can you let me know how to attach the photo?
05-20-2022 09:00 AM
I'm pretty sure you'll need a C-wire running from the furnace control board to the empty "C" slot on the Nest. 99% of the issues people have with the Nest are because the C-wire is not connected. Also, check that your "Y-wire" is connected properly, this controls cooling.
