Display current temperature with Farsight not working on Gen 3 Nest
BenjaminIan
Unable to display current temperature with Farsight even when i have it selected on the thermostat. Currently the current temperature is higher than the target temperature. I have tried ECO,HEATING and OFF modes.
I was able to select digital clock and that worked. Unfortunately current temperature settings using farsight doesn't.
We installed the Nest for the LP gas stove as a backup heat source to our wood stove upstairs and pellet stove downstairs. When away the Nest app can display inside temperature to tell us the house temperature is ok.
6 REPLIES 6
I must have to admit that I am not aware of what farsight is in the Nest app or the nest thermostat. Can you please take a moment and explain it to me so I can learn?
The AC Cooling Wizard
aatienza
BenjaminIan, thanks for reaching out. Try changing what Farsight displays or like to turn Farsight off. Follow the steps below and let us know how it goes.
  1. Go to Settings > Display.
  2. Select Farsight.
  3. Turn the thermostat ring to select what Farsight can display. To deactivate it, select one of the options from the Don't use Farsight section: Wake on approach or Wake on pressing.
CoolingWizard, Farsight is a function available on the Nest Learning Thermostat (NLT) that allows the customer to view information on the thermostat display from a distance. By default, Farsight is set to On and displays the target temperature. The customer also has the option to change the display to show the ambient temperature, time, or current weather. This function is not available on the Nest Thermostat E.
Archie
Thank you for the clarification on Farsight. Once you described I was aware of the function, must not feature name.
AC Cooling Wizard
Jeran
Thank you for helping out on this thread, CoolingWizard and aatienza!
Hey there BenjaminIan,
I'm just checking up on this thread, do you have any more questions or need any additional help?
Jeran
Jhonleanmel
Chiming in to see if you still need assistance with this. Let us know if you have additional questions ― we'd love to help.
Mel
Jhonleanmel
Mel
