Gen 2 Nest thermostat to control switch to ceiling fan when set point met
Snebarekim
I have a Gen 2 Nest thermostat that controls my A/C and furnace.
i also have  dumb (no remote) Hunter ceiling fans on a standard dumb wall switch in my living room and 3 bedrooms.
I would like the ceiling fans to come on ONLY when the Nest thermostat is actively calling for heat/cooling, so a smart  wifi controlled wall switch I could install (and leave on) would do the trick.
Is there any compatible smart wall/light switches known that will do this?
The only ones I can find that are compatible with Nest thermostats (like Levitron) only turn on switches via voice command or in "Away", I want a switch that triggers when the themostat calls for cooling/heating and turns off once set point is met.  All suggestions welcome!
Jhonleanmel
Hey Snebarekim,
We appreciate your interest however, we don't have any news to share about a switch that triggers when the thermostat calls for cooling/heating and turns off once the set point is met. We're always looking for ways to improve and we'll take it as feedback.
I also suggest that you send feedback by following this link. Let me know if you have other questions or concerns, otherwise I’ll be locking this thread after 24 hours.
Jhonleanmel
Hey Snebarekim,
