12-06-2021 11:55 AM
My Heat Link suddenly stopped working, can't be turned on, no power light at all. I've tried to reset it by pressing and holding a button for 10, and 20 seconds but it didn't help. I've checked wiring connections, everything seems to be like it should. There is power on both 240V wires.
Any suggestions?
12-06-2021 11:59 AM
Few more details using some question in a similar post
How long has your thermostat been installed for? 2 years 6 months
Did the issue happen during the installation? Not issues during installation
Is there any error on the Nest thermostat display? No error but it has no power as it being charged via heat link. I can charge through USB
Have you had any power cuts recently? No
Have you had any work done on your electrical or heating systems recently? No
How many zones ( thermostats ) are present in the setup? 1
12-13-2021 09:15 AM
Hey @Ango31,
Thanks for reaching out! I'm sorry to hear about your issue, but I'll help you sort this out. Please tell me if you've tried to power cycle the Heat Link and if you tried to put it on Manual Mode afterwards to see if the boiler will activate.
12-18-2021 06:47 AM
Hi, I wanted to check in. Do you need any further assistance?
If so, make sure to let me know.
01-07-2022 04:11 AM
