H71 problem need help!
Clarkie96
Had a nest and heating link installed not even 3 weeks ago. Got a message today from the nest saying issue H71
tried resetting just stays a solid yellow light even after turning off. Tried turning off from the fuse, reset the wifi. Moved thermostat closer to the boiler.
having no luck! Would this be a whole new heat link?
Frustratedddd
Any lights on the Heat Link?
You say yellow light, if that is on the Heat Link it's not dead. Have you reset the Heat Link?
Which generation do you have?
