Heat link, Lost power. H71 Error showing
Chris1000
Hi.
My heat link stopped working on Sunday and the thermostat is showing a H71 error. I've tried holding manual button on for 20-30 seconds but still no leds lighting. The boiler is working correctly as upstairs runs independently from the Nest.
I think I need a new heat link installed.
6 REPLIES 6
Frustratedddd
I think you do as well..!
CristianC
Hi @Chris1000,
Thanks for reaching out. I'll do my best to get this sorted for you as soon as possible.
Here are some helpful troubleshooting steps:
Press the button on the Heat Link and check if you have any lights on it
Check if the circuit breakers and the switches are set to on
Turn them off and then back on
Press on the button again and check for LEDs
Could you also help me with some answers to these questions?
How many zones are present in the setup?
Cristian
Hi Christian.
I have checked all switches circuit breakers and there are no faults. Turned on off and still no LEDs lighting up.
How long has your thermostat been installed for? 28 Months.
Did the issue happen during the installation? No worked fine for 2 years
Is there any error on the Nest thermostat display? Yes as mentioned in original post H71.
Have you had any power cuts recently? No
Have you had any work done on your electrical or heating systems recently? No.
If yes, was the power properly restored at the fuse board after work was done? N/A
How many zones are present in the setup? 2, Water and Downstairs.
Chris
CristianC
Thanks for the details. I want to open up a case for you — please fill out this form so I can gather your details securely and let me know once you've done it: https://bit.ly/3oVDg4g. Please include the serial number of the thermostat, your full shipping address and the email address linked to your Nest account. Don't forget to put in your community username as well.
Hi Christian.
I've done as requested.
Chris
CristianC
Thanks for getting back to me. I sent your case to our senior team for review. They'll reach out to you with a resolution in the next 24 - 48 hours.
