08-11-2023 05:44 PM
I am having some issues connecting my Nest thermostat to WiFi. The setup code is on back of thermostat and I cannot remove thermostat from wall, i love in an apartment.
08-11-2023 06:59 PM
You can also get the code thru the nest menu. Good luck
08-18-2023 12:50 PM
@RALombardi, thanks for reaching out to us, and I'm sorry to hear about the situation. I want to check and see if you are still in need of any help. If so, please follow these steps to scan the QR code on your thermostat:
For Nest Learning Thermostat and Nest Thermostat E, go to its Settings > Nest app > QR Code. For Nest Thermostat 2020, you can select Continue without Scanning on the Google Home app to proceed.
Let us know how that works.
I appreciate your help, @HVAC.
