Help installing nest with power cable on older 2 wire electric heater
Irishscout
Have a 2 wire electric forced air heating system. I got everything hooked up and seemed to be working I just know where to put the c connector in the power stabilizer. There is no circuit board, I figured I'd just put it 120v wire and that didn't work worried I messed it up now! Please hep
One thing you need to understand and remember is that the nest thermostat like all traditional and conventional thermostats operates on 24 V of AC power. Not 120 V or 240 V. The same is true about the power connector it is designed to work with 24 V of AC power. When your system is a forced air system, your 24V Power Common is inside the forced air unit not on the heater itself. Now do you have a nest power connector, or what is the thing you called a “stabilizer”?
The AC Cooling Wizard
We appreciate your help here, @CoolingWizard.
@Irishscout, I wanted to follow up and see if you are still in need of any help. Please let me know if you are still having any concerns or questions from here, as I would be happy to take a closer look and assist you further.
Mel
Mel
Mel
