How do I click on settings
Chuck3
How to I access settings to check my battery
David_K
  1. Open the Google Home app.
  2. Touch and hold your device's tile.
  3. Tap the Settings cog at the top right.
  4. Select Device information.
  5. You can see the charge level of the batteries next to Battery state.
Nest thermostat's technical information - Google Nest Help
Jhonleanmel
@David_K, appreciate your helpful response.
@Chuck3, chiming in to ensure everything is good here. Have you had the chance to try the suggestion above? If yes, how is it?
Mel
Hey everyone,
I wanted to follow up and see if you are still in need of any help. Please let me know if you are still having any concerns or questions from here, as I would be happy to take a closer look and assist you further.
Mel
