How hard is it to get a replacement for my Nest Thermostat that doesn't show the display anymore?
TbabyShabazz
My Nest Thermostat hasn't worked right from the beginning.  WiFi is never connected, always says replace batteries, even if they're new batteries, and now there's no display, beep, or sign of power.  PLEASE, it's getting cold outside and inside, How can I get, at least a refurbished replacement for my Nest thermostat?
2 REPLIES 2
@TbabyShabazz
You could try contacting Support using the link and instructions in this post:
Lance_L
Hello TbabyShabazz,
Thanks for reaching out to the Community.
I’m sorry to hear that you’re having issues with the Nest Thermostat. I wanted to check if you still need any help. Were you able to contact the support team as MplsCustomer suggested above? If yes, how was it?
If you haven’t done so already, here’s a guide to help you troubleshoot when your thermostat won’t turn on.
Lance
