I have an R and RC Wire Help with install please Where does RC Go?
JamesBombo
Since I have an R and RC, Where does RC Go?
See photos  below
You have what is called a dual transformer system and only the Nest 3rd Gen Learning Thermostat is compatible with it.
Your heating and cooling system are separate, the W and R terminals are for heat. The Y, G, and Rc terminals are for cooling.
Ryan_G
Hi JamesBombo,
Thanks for reaching out here at the Google Nest Community.
I'd like to jump in here and check if you've seen Patrick_Caezza's response. We could try his wiring configuration suggestion and let us know how it goes.
Ryan
Ryan_G
Hope this helps!
Kind regards,
Ryan
