06-15-2023 10:34 PM
hello All
i have a newly installed Trane HVAC system. Wiring attached in the photo.
mu HVAC professional says I cannot install nest thermostat on it.
is this true?
06-19-2023 03:32 PM
Hi Hadimas1,
Thanks for reaching out to us, and for showing interest towards our Nest Thermostats. I see that your control panel has the non-standard labels of N, L, M, and H which means that your system is proprietary.
Proprietary systems aren’t compatible with Google Nest Thermostats. Also, Nest Thermostats are only compatible with solid copper wire thermostat wires, so if you want to switch to our Nest Thermostats, I recommend you contact our Pro Installer so that your system will be rewired to be compatible.
Let us know if you have any other questions. We're happy to help.
06-22-2023 04:52 PM
I wanted to check and see if you are still in need of any help. Please let me know, as I would be happy to assist, and answer any questions you may have.
06-25-2023 05:22 PM
Hey Hadimas1,
I'm just checking in to make sure that you've seen our response. Please let us know if you have any other questions or concerns, as I'll be locking this thread in 24 hours.
I appreciate your help, Zoe.
