Locked nest thermostat and no pin
Dperry
I am not sure what issue my nest thermostat is.  It is locked and I do not know the pin.  I pulled the main nest control off but there are no numbers or codes.  What do I do now?
9 REPLIES 9
David_K
If your thermostat is still connected to Wi-Fi and you can see it in the Nest app or Home app, you can unlock and reset the PIN using the app:
Lock and unlock your Nest thermostat - Google Nest Help
If you can't control it using the app anymore, you'll need to reset it using a computer.
  1. Connect the Nest Thermostat display via USB to a computer.
  2. Verify that the Nest Thermostat mounts (appears as an attached drive icon).
  • If the Nest drive will not mount: Restart the thermostat and the computer.
  • If the Nest drive still won't mount: Connect another device to the cable to see if it appears as an installed device.
  • If it doesn't appear, use a different cable/port/computer.
If the Nest drive is successfully showing up on your computer, can you see a technicalinfo.PLIST file? If you get this far let me know and I'll ask a community specialist to assist with next steps, as these can't be shared publicly in the community.
Dperry
I now have on my computer "Technical Info.plist".  Am waiting for further instructions.
David_K
That's great. I've asked a specialist to chime in here for next steps.
Dperry
Then how do we proceed?  Do you call me or email me?
David_K
Within 24 hours or so they'll reply here with next steps.
zoeuvre
Hi Dperry,
I appreciate the steps you have taken so far. We’d like to take a look at this for you. Could you please fill out this form with the needed information?
Thanks for the help @David_K
Dperry
I sent in the filled out form.  Hopefully you received it.  Am waiting for the next steps.
Dperry
Are you going to help me with my problem?  I have been waiting for a week for help.
Hello folks,
Thanks for assisting, Zoe.
@Dperry, thanks for completing the form; we have received it. Soon, a member of our upper team will contact you via email. Also, please continue the conversation there, as this thread will be locked within 24 hours.
