Nest 3rd Generation battery failure
Randyt
Offline, battery low recharge on USB but goes offline in a few days???
@Randyt ,
You need Common wire or add a Nest Power Adapter. Do that and all will be better.  I would love to help you to find out if you can add a common wire or if you need assistance adding a Power Adapter, I will be happy to help explore your capabilities.
AC Cooling Wizard
zoeuvre
Hi Randyt,
Thanks for posting here in the Community forum, and I’m sorry to hear about the situation. Let’s sort this out.
Can you help me with your Nest Learning Thermostat's power reading?
  1. To open the Quick View menu, press the thermostat’s ring.
  2. Choose Settings.
  3. Turn the ring to highlight Technical Info then press the ring to select it.
  4. Select Power.
    • Battery
    • VOC
    • VIN
    • IIN
I appreciate your help, @CoolingWizard
Chiming in — could you please provide the needed information asked above? It will help us to move forward.
I appreciate your help, @CoolingWizard and Zoe.
Hello there,
I'm just checking in to make sure that you've seen our response. Please let us know if you have any other questions or concerns, as I'll be locking this thread in 24 hours.
