Nest Heat Link - No power
Dolapo
Hi - I’ve just suddenly got a H71 error on my nest thermostat. I’ve tried all the troubleshooting but there is no lights on my heatlink.
has anyone experienced this and if so, what’s the resolution? My best controls both heating and hot water so I’m kind of screwed.
ive tried going to this (https://support.google.com/googlenest/gethelp?hl=en) and am not having any luck and it’s telling me to contact during opening hours, while also saying opening times are 24 hours.
9 REPLIES 9
scottcharlie
We are experiencing the same problem. I will be interested to see what answer you get. I had a electrian round and they have advised heatlink dead... ours is 14 months old!! see what happens tomorrow.
The link works for me!
I tried between the hours of 8am-7pm, quicker than waiting here for an answer.
Yes you’re right, called this morning at 8 and got straight through to someone.
Brief triage, but then quickly realised it was kaput.
new heatlink being sent out and they are also willing to fund getting a temporary thermostat (up to £50) and the engineer call out fee to fix the temp thermostat (until the new heatlink arrives) and then to fit the new heatlink once here (£100 per visit)
All in all, pretty swift resolution.
CristianC
Hello everyone,
Thanks for reaching out. I'll do my best to get this sorted for you as soon as possible.
Here are some helpful troubleshooting steps:
Press the button on the Heat Link and check if you have any lights on it
Check if the circuit breakers and the switches are set to on
Turn them off and then back on
Press on the button again and check for LEDs
Could you also help me with some answers to these questions?
How many zones ( thermostats ) are present in the setup?
Cristian
Dolapo
Thanks for the post. Tried all the troubleshooting methods and none worked and there have been no power supply issues.
So it is just a failed heatlink. But new one being sent out now, so should all be sorted.
Will update on progress 😁
AnaM
Hey @Dolapo,
I'm glad to hear you've got it sorted over the phone. Should anything else come up, don't hesitate to reach out to us.
AlexD
Hi, I wanted to check in. How are things going, do you need any further assistance?
If so, make sure to let me know.
Dolapo
New heatlink arrived and installed, so all sorted. Thanks all
AlexD
That is great to hear. If anything else comes up, make sure to start a new thread. I'll lock this one down.
