Nest Learning thermostat doesn’t work in heat/cool
boaterva
Used the thermostat for a year, no issues. Set to heat/cool, schedule set. Eco off. Home/away off. Just like a plain scheduled thermostat.
We go on vacation, so I set it to Eco to save some money perhaps. We come back, change it back to normal, trouble starts. When the schedule calls for heat or cool, the app shows orange or blue but it does not actual send commands to the HVAC (no heat or cooling stage 1 or 2 response). If I click on the appropriate Heat or Cool mode, it works immediately.
Done a restart of the thermostat, no change. I was about to do a reset but thought I’d see if anyone had an idea. What would do this or would fix this? Thanks!
boaterva
This looks like it was a network issue.  The wifi had some issues where the thermostat (and other device) could not get a good connection (even though they were connection).  If your thermostat shows calling for heat/cool but no response or not responding to schedule (I've seen quite a few), might want to restart router/access point, etc. to be sure!  Thanks to those that gave a suggestion, but looks like it was an external issue.
10 REPLIES 10
MrVacca
Silver Product Expert
Hi @boaterva
Sorry to hear about that. Maybe if you delete all your schedules and reset the eco temperatures to a different degree, it might be able to reset it.
boaterva
I’m not using eco, as I stated. I can redo the schedule but that’s not the point either. It’s that the schedule triggers the thermostat but it doesn’t actually do anything.  It calls for heat or cool but HVAC doesn’t start.
Makes zero sense that putting it in eco for four days breaks it totally.
boaterva
EdwardT
@MrVacca, thanks for the help!
@boaterva, I'm glad to hear that you were able to figure out the issue. Please observe it for now and let us know if anything comes up.
Edward
EdwardT
Hi boaterva,
Edward
boaterva
Actually, it still doesn't work, and I'm dumping it.  There is no reason for it except it died.  As I said, nothing changed except the vacation trip in Eco mode and returning it to normal mode.  Now it calls for heat for over 15 minutes and doesn't start the furnace.  Changing modes makes it work.  Useless.  This was a freebie when I got other hardware, so, means nothing to me.  Even reset the schedule as recommended (which should not matter), no effect as it DOES call for heat, it just doesn't complete the command.
EdwardT
Hi boaterva,
Thanks for the update. I'm sorry to hear that you're still experiencing this. To isolate the issue, please try doing a factory reset on the thermostat. You can click on this link for step by step instructions on how to factory reset it.
Let us know how it goes.
Edward
EdwardT
Hi boaterva,
Edward
boaterva
Nope, as I said, I dumped this hardware for an Ecobee, which works perfectly.  Please close this.  I didn't reopen it.  🙂
EdwardT
Hi boaterva,
Thanks for responding. We're sad to see you go. We hope we can make it up to you in the future. I will be locking this thread in 24 hours. Please feel free to create a new thread should you have some more questions or concerns in the near future and we'll be more than glad to help.
Edward
