03-24-2022 12:56 PM
I installed the nest thermostat on a 2 wire system and had the N260 error message. I then installed the nest power connector to solve the error message now I am receiving the N261 error message. I checked the voltages and have 25vac on the input to the power connector and 25 vac between the C and R wires but nothing between the R and W wires and nothing between the C and W . The thermostat does not detect the W wire . I don’t know and cannot find what I should measure between the R and W or the C and W wires. Can anyone please help.
03-24-2022 03:36 PM
What type of 2-wire system are you trying to set up?
03-24-2022 05:28 PM
It is an oil fired hot water baseboard with a Honeywell controller on the NTI boiler
03-25-2022 08:53 PM
Good chance you will need to add an external 24VAC transformer.
Here is an example of what I am talking about.
03-30-2022 09:09 AM
Thank you for your help. I gave up on the thermostat and returned it. I will look for one that will work without the ancillary equipment that the nest requires.
04-06-2022 04:30 AM
Thanks for providing the diagram and for answering, Patrick_Caezza.
RobertNorth, sorry that you had to go through this and we're sad to see you go. Should you be willing to give us a chance again in the future, you know where to find us.
Melba
04-11-2022 10:58 PM
I haven't heard from you in a while so I'll be locking this thread if there is no update within the day. If you have any new issues, updates or just a discussion topic, feel free to start a new thread in the community.
Melba
03-25-2022 08:23 AM
Do you have a nest power connector unit if so could you please measure the voltages between all wires of the output and let me know what you measure
