08-23-2024 09:02 AM
2020 American Standard HVAC system.
Old thermostat wired:
Green wire to G
White wire to W
Blue wire to C
Yellow wire to Y
Red wire to R (R jumper to Rc)
Nest:
Yellow wire to Y1
Red wire to R
Green wire to G
White wire to W
Blue wire to C
Connections are long enough, clean, tight.
Furnace display shows 7p1. System worked correctly prior and I did disconnect power before beginning,
What am I missing?
08-23-2024 09:02 AM
Sorry, it is a Nest E that I am installing.
08-24-2024 03:05 AM
Just connect with micro usb charger for 15mins and it should back to normal.
