Nest Thermostat & LG Heat Pump System
Thexsf1
I have a fairly new LG Heat Pump system. The existing LG Tstat only has Yellow (signal), Red (12v), & Black (ground).
Is the Nest compatible & where does the ground get connected to (G slot?)?
EdwardT
Hi Thexsf1,
Thanks for reaching out. It looks like the wiring of your current thermostat is proprietary. I'd love to know more about this. Could you share a photo of the control board of your heat pump system?
Edward
I wanted to check in and see if you managed to see Edward's post. Please let me know if you have any questions from here. I would be happy to assist, and make sure you are good to go.
Thexsf1
Ok - I gave up & returned the Nest.
I am sorry to hear you no longer have the device. With that being the case, I am going to go ahead and lock the thread at this time. If you have any questions from here, please feel free to create a new post.
