11-13-2021 01:15 PM
Hi
My Nest Link is dead. I have it just over a year. It won't reset when I hold button for 10 seconds or when I turn off and on power. It won't respond to counter top reset either. I have no heating 😞
Angela
11-13-2021 02:05 PM
same for me - just died ... and no support till 9 am tomorrow..
11-15-2021 12:25 AM
My heatlink died as well, it is 13 months old...NOT happy. It is getting mains voltage, there are no lights on it. Phoned google support an they went through tests, then asked me to send in a pic of the heatlink and its location. This expensive piece of equipment should last for 10 years +..not ONE year. There must be a batch with faulty components as ours died at 12 months.
11-15-2021 03:30 PM
4 calls to get to support team... electric Ireland sold device and fitted.. they won't replace with upgraded one.. they wanted 65euro to get my heating back in to old control panel... referred to Google support team. 3-4 days to receive replacement Nest. I have to find electrician to fit! Then send back crap broken Nest with invoice for payment. No problem getting technician to fit but not to fix!! Seriously! Why would I want another Nest. SERIOUSLY!
11-16-2021 07:05 AM
Angela, i had the same problem and they are sending out a replacement unit. They are offering to refund the replacement cost for a sparky to swap it out. But you do need to get an invoice from the sparks. Most companies just send out the replacement an thats it. I am fortunate in that i left my old electromechanical thermostat fitted, just turned down and I can control the boiler from that. In your case, just arrange a sparks to swap out the heatlink. Its not worth stressing over it.
11-16-2021 07:36 AM
Correct Google shipped replacement - installed it in 15 mins - all ok now - happy with support received
12-01-2021 09:19 AM
Hello everyone,
I'm glad to hear that you all received a replacement. Let me know if there's anything I can do for you.
12-10-2021 08:08 AM
Hi, I wanted to check in. Does anyone require any further assistance?
If anything comes up, make sure to let me know.
12-13-2021 04:49 AM
It's been a while since this thread was last updated so I'll go ahead and lock this thread. If you're still experiencing problems, please feel free to start a new thread and we'll be happy to help.
