08-08-2023 11:20 PM
All of the sudden yesterday our ac will not cool to set desired temp. It ran all night set at 72 degrees with the best saying “ reach temp in 2 hours” but the temp still stayed at 77 degrees and never went down nor did the ac stop all night or all day. My husband changed the filter today and I was hoping that would fix it, but it’s still been hours with the ac running and the temp still reads 78 degrees and won’t get to 72 degrees for 2 hours. What do we try next. I’m scared to know my Edison bill after 24 hours straight running with no true temp change.
08-09-2023 12:00 AM
Was filter plugged up? Try leaving off for 3-4 hrs maybe it was iced up. Then try it & if you can feel good airflow blowing out but not cool then it’s outside unit that’s not working.
08-09-2023 01:33 PM
I turned the ac off for 4 hours and still not as cool as normal Not blowing warm air just not cool, nest still says won’t get to desired temp for 2+ hours. What’s next?
08-09-2023 02:13 PM
Outside AC unit is not running can be multiple things etc breaker is tripped or fuses shorted maybe due to capacitor or other failures. Best option is contact AC tech to check. Good luck.
08-09-2023 05:32 PM - edited 08-09-2023 05:33 PM
Your system needs to be serviced. Have them verify the indoor coil is clean, and have the outdoor condensing coil cleaned and check the system performance by verifying the Sub-Cooling and Super Heat meet the manufacturer specifications.
AC Cooling Wizard
08-09-2023 08:37 PM
Literally the exact same thing happened to us last night. Left it off for a few hours during the day, turned back on, seemed to be okay and then happened again. Whole unit froze up, turned it off for a good while to thaw out. Now it's running cool air but thermostat temp still not going down below 76.
08-09-2023 10:15 PM - edited 08-09-2023 10:15 PM
There are a couple reasons why the indoor unit will ice up. Poor air flow or low on refrigerant. The poor air flow can be dirty or plugged up filter or a dirty or plugged up coil. If it is a refrigeration leak in your system, you will damage the compressor if you keep running the system on low refrigerant. I encourage you to call a company to service your air conditioner.
AC Cooling Wizard
08-13-2023 04:53 PM
Thanks for reaching out. I'm sorry for the delay. I just want to check if you managed to see the response above. Please let us know if you still have questions or concerns, as we'll be willing to assist you further.
I appreciate the input, @HVAC and @CoolingWizard.
08-17-2023 08:28 AM
@JMans and @aishabelal90, I wanted to follow up if you still need help. Please let me know if you’re still having any concerns or questions from here, as I would be happy to take a closer look and assist you further.
08-22-2023 05:30 AM
I am having the same issues and my AC was serviced prior to moving in and worked for a couple days now its not changing temperature from 80 (i live in florida with animals)!! It says it will take 2 hours to change and never does. I have been sending messages to this forum for a week with no repsonse!!! How does Nest stay in business????
08-22-2023 08:29 AM
@debi926 ,
I looked for your other messages you claimed to have posted for weeks and I never found them. You say your HVAC system is not cooling efficiently and it does not cool your home below 80°F? Does your coil ice up as like the original poster has stated? You say your system was recently serviced and it worked fine for 2 days. What did the service technician specifically do to your HVAC system?
AC Cooling Wizard
