3 weeks ago - last edited 3 weeks ago
My Nest is working only on battery power. My old thermostat had a red wire to the RH with a jumper to RC, W, Y, and G. My unit only is used for heat. When I wired into the Nest I used the Y, W, G, and R. No other jumpers. What do I need to do?? Thank you.
2 weeks ago
Hi CMMooney,
Thanks for reaching out. I'm sorry to hear that you're having an issue with your Nest Thermostat. I'd love to know more about this and I have a few questions:
Edward
2 weeks ago
Hi CMMooney,
Edward
2 weeks ago
Hello CMMooney,
I'm checking in to make sure that you've seen our response. Please let us know if you have any additional questions or concerns before we lock this thread in 24 hours.
2 weeks ago
Well, I would send phots of everything but I cannot figure out how to do that on this application. I currently reverted back to my old thermostat and cannot get of the power readings. I will have to wait to do so until this weekend.
I have the Nest Thermostat https://store.google.com/us/config/nest_thermostat?hl=en-US
I have the (Y)ellow in the Y, (W)hite in the W, (G)reen in the G and the Red wire that was plugged in to the Rh on my old thermostat in the R. On my old setup there was a jumper from the RC to the RH.
2 weeks ago
Thanks for getting back to us, @CMMooney. I appreciate you keeping up with our Nest Thermostat. I'd be happy to take a look into this for you.
Nest Thermostats don't require a jumper wire. If your current thermostat has this, your system is still compatible, and you do not need to use it. You can follow the same wiring setup as what you mentioned in your original post as your guide and leave the Y wire disconnected, as it was used for cooling.
If there’s anything else I can help you with, please let me know.
2 weeks ago
I will give this a try and let you know if it works.
a week ago
Hello everyone,
@CMMooney thanks for getting back to us. Sounds like a plan. Keep us posted.
I appreciate the help, Edward and Mark.
a week ago
Hi CMMooney,
It's me again. I'm checking back in — how's it going? Were you able to install your new Nest Thermostat? Please let us know if you still need help so we can assist you right away.
Tuesday
Hello CMMooney,
It has been a few days since your last reply, and I am going to lock the thread within 24 hours. If you have any questions, please feel free to create a new post.
Tuesday
I was able to wire the nest back up. My voltage reads 3.014 and Impedance is 1200mOhm.
Also Vin; 31.029V lin; 68(w) ps; y-16, YW-68.
Everything is saying to install the nest power connector or C wire so I will order the Nest power connector.
Wednesday
Thanks for letting us know your thermostat's power readouts. It appears that it's not getting enough power from your system. Installing a Nest Power Connector can help provide constant power to your thermostat. Here are some references to help you install your new Nest Power Connector on your HVAC system.
yesterday
Hey CMMooney,
Chiming in to see if you still need assistance with this. Hope the previous post helped. Let us know if you have additional questions ― we'd love to help.
Abi
yesterday
I am waiting for the power connector to get here still should be here tomorrow or the next day.
