Nest pro compatibility with nest temperature sensor
wlosek64
I would like to purchase a nest temperature sensor for use with my nest pro thermostat.  I want to know if the 2 devices are compatible with each other.
10 REPLIES 10
David_K
The Nest Temperature Sensor works with the following thermostats:
  • Nest Learning Thermostat, 3rd generation
  • Nest Thermostat E
For the following countries:
  • United States
  • Canada
  • Mexico
Jhonleanmel
We appreciate your help here, @David_K.
@wlosek64, I wanted to follow up and see if you are still in need of any help. Please let me know if you are still having any concerns or questions from here, as I would be happy to take a closer look and assist you further.
Mel
gsd101
I have the same question as posted earlier.  I have a Nest Pro and would like to use a sensor.  However, I am unable to pair the two devices.  I can pair the sensor with my other Nest Learning Thermostat, but it is not working with the Nest Pro.  Am I doing something wrong?
Jhonleanmel
Hi gsd101,
Could you clarify what you meant by 'Nest Pro' device? Check this link for the list of Nest Thermostats we have: Nest Thermostat technical specifications
Mel
As far as I know, there are two versions of the Nest Learning thermostat, the home and pro.  The home is the one that anyone can buy through retailers such as Home Depot and the Pro is the version that dealers and installation professional use.  I have two systems in my house and one has the home version and one has the Pro version.  Does that answer your question and are you familiar with the two different types of thermostats?
Jhonleanmel
Hi gsd101,
Thanks for clarifying that. Yes, your Nest Learning Thermostat, 3rd generation purchased from the countries mentioned above should be compatible with the Nest Temperature Sensor.
Mel
Hey gsd101,
Mel
Hi gsd101,
Mel
Thank you, I no long need assistance. I resolved the problem by factory resetting the unit and then it was able to recognize the sensor.
Jhonleanmel
Hey gsd101,
Awesome — glad to hear that your issue is fixed. It looks like we can consider this one complete, so I will lock the thread shortly unless I can help out with anything else.
Mel
