Nest thermostat compatibility with Trane Heat pump
rockstx
I have a Trane heat pump system.   When I use the Nest install app, it says my system may be incompatible.   See wiring below.  Can anyone tell me how to wire to the Nest 3rd Gen Thermostat?
You have a heat pump system so use the outer labels.
White - W1 to W2/AUX
Blue - B to C
Green - G to G
Yellow - Y yo Y1
Orange - O to OB
Red - R to Rc (jumper to RC not needed)
6 REPLIES 6
Blue - B to C
Green - G to G
Yellow - Y yo Y1
Orange - O to OB
Thanks !  I’ll give it a try and let you know.
It worked !  A/C running fine.  Nest app wouldn’t let me test heating because it’s over 90 degrees outside.  Thanks for your help.
Jeran
Hiya rockstx,
I'm glad that Patrick_Caezza was able to help you out! In that case, did you have any other questions or concerns we can address?
Jeran
rockstx
No other concerns at this time.  All is good so far !!
MelbaDT
Thanks for getting back to us and for confirming that everything is working as it should. We'll consider this as resolved and we'll lock this thread after 24 hours. If you have any new issues, updates or just a discussion topic, feel free to start a new thread in the Community.
Melba
